Voltage drop greater than voltage supply
JackBidds
Joined Jan 10, 2021
17
Ok so I am currently watching a video on Kirchhoff’s Voltage Law and something has been bugging me. In the attached picture we are working out voltage drop/gain along components. Along the top resistor the voltage is 12v before it and somehow it has been calculated that the voltage drop over the resistor 12.5( larger than the voltage before it). How is this possible
ericgibbs
Joined Jan 29, 2010
21,622
hi J,
OK.
Look at these 4 same circuits with the 0V point in different locations, the 0.25A is always the same.
The 0V label is just a reference point not a applied voltage.
E
bertus
Joined Apr 5, 2008
23,023
The sum of the voltages accross the resistors should be the same as the sum of the voltage sources.
Bertus
JackBidds
Joined Jan 10, 2021
17
hi J,
OK.
E
Ok thanks but why is it called 0v if it’s not actually 0. How can this be possible
ericgibbs
Joined Jan 29, 2010
21,622
hi J,
It is just a Common reference point for the circuit.
Say you were using a Voltmeter to measure the voltages around the circuit.
You would clip the -neg probe of the meter to 'A' and use the +positive probe of the meter to measure B , C or D.
So A is the reference point for the voltages.
The 0V means on your circuit, its a reference point, just a Label.
E
JackBidds
Joined Jan 10, 2021
17
hi J,
E
Ok I think I get it now, so it doesn’t have to actually be 0 volts
ericgibbs
Joined Jan 29, 2010
21,622
But If the voltage is 0
Hi J,
There is no voltage, it just a label like A,B,C,D
The 0V is not in the resistor loop, its just a reference point.
Consider you had a car, the chassis of the car is connected to the -neg of the battery, the chassis would be considered the 0V reference.
E
JackBidds
Joined Jan 10, 2021
17
Hi J,
E
So could I pick any number as the reference point not just 0?
djsfantasi
Joined Apr 11, 2010
9,237
Yes, but what is that “any” number in reference to? Voltage is always measured as the difference between two points. If you assign some other number - then there is another point in the circuit which should be labeled 0V. To confuse you further, this point could be internal to a component... but it does exist. Careful selection of values will remain consistent and there will be a physical node that is at 0V.
JackBidds
Joined Jan 10, 2021
17
Yes but if I can just randomly label anywhere as 0 when it’s not then surely somewhere else in the circuit must be 0
djsfantasi
Joined Apr 11, 2010
9,237
So I could label the point as 10 volts instead of 0 and everything would still work out the same?
I think the correct answer is no. The voltage at every other point would be +- 10V, since you changed the definition of your reference point.
This is purely theoretical, as no one but you would make that change. The point I am trying to make is that voltage is defined as the difference between two points. If A is 0V and B is 12V, the voltage between the two points is the same as between A=10V and B=22V.
RBR1317
Joined Nov 13, 2010
715
If a circuit has no ground reference for measuring voltage against, then there is a standard notation for expressing voltage drops. Vab is the voltage at point A with respect to point B. So Vab = -Vba.
