voltage drop and fluctuate
I can't find where the problem in supply section.
  • problem solution
    Votes: 0 0.0%
  • why this problem occurs
    Votes: 1 100.0%
  • Total voters
  • Poll closed .
luise
Joined Mar 1, 2017
20170301_123903.jpg 20170301_132426.jpg Hello
Fluctuating voltage come on Battery terminals 6v to 7 v dc. It should 12v dc.
I have replaced the transformer, lt1725 ic , all diodes, electrolyte capacitor and triac but problem is still. Transformer secondary voltage fluctuating 10 to 12 volt ac.
I have checked in working board, remove the secondary wires when I found transformer output voltage is 90 v ac.
Pls find the attachment.
djsfantasi
Joined Apr 11, 2010
9,237
I am not sure why you are getting 90 VAC on pins 5 & 6? It should be 0V. Transformers require AC input and I expect them to do nothing if DC is supplied instead.
Dodgydave
Joined Jun 22, 2012
11,395
The chip bottom right corner, LT1725cs is a Switchmode psu chip, and is probably pulsing the Transformer.
Can we have the Full Picture of what this pcb is used for?
profbuxton
Joined Feb 21, 2014
421
Without more details,I would hazard a guess that whatever is driving the transformer is "stuffed". It looks like some sort of switched mode charger, is that correct. Make sure that whatever drives the transformer is working correctly. Also check output circuit has no problems causing low output etc.
If this is a SMPS supply so you cannot disconnect the secondary windings and read the voltages. These voltages are not going to be what a working circuit is going to have. The secondary AC output is going to converted to a DC voltage and a portion of it is fed to a voltage comparator circuit to monitor regulation. If the voltage is too high or too low then an offset/correction voltage is fed back to the primary side to modify the duty cycle to bring it back to proper regulation. This feed back are generally sent back from the secondary to the primary circuits via an opto-isolator chip. I cannot see enough of the circuit to determine if this is an SMPS (switched mode power supply).
