Voltage doubler
YoGMan
Joined Sep 20, 2017
76
Hello guys
I'm studying the voltage doubler circuit as shown below and I have a confusion.In the first stage,C1 is charged to Vm (note the current direction) but in the second stage, c2 is being charged to 2Vm BUT this time the current is in opposite direction.Doesn't that mean C2017-10-09_153056.jpg 1 should be discharged?
dendad
Joined Feb 20, 2016
4,642
Yes, it does, partly loose its charge, how much is depending on the charge held in the next capacitors. But it has its charge transferred to C2 as the AC is now "pushing" it by being in series adding to the C1 voltage.
Any lost charge will be topped up on the next half cycle.
AnalogKid
Joined Aug 1, 2013
12,297
Hello guys
I'm studying the voltage doubler circuit as shown below and I have a confusion.In the first stage,C1 is charged to Vm (note the current direction) but in the second stage, c2 is being charged to 2Vm BUT this time the current is in opposite direction.Doesn't that mean CView attachment 136898 1 should be discharged?
Semi. If C1 and C2 are equal, C1 gives up half its charge to C2. Two capacitors in series form a voltage divider just like resistors.
ak
YoGMan
Joined Sep 20, 2017
76
Thank you for the quick reply guys ,I attached a video which explains the voltage doubler below - It starts @02:10 .Here I see that the output voltage peak is 2Vm after several cycles of the input voltage.In all books I've read it does not mention about the cycles and discharging of C1 as seen in the video, they apply KVL directly to get Vout=2Vm (see the picture2 below).So guys, Is the explanation for the voltage doubler correct according to the book or to the video?- According to me , the real way and best way to explain the circuit is as the video , I think the book assumes the steady state behaviour of this circuit .I need your advice on this ,Am I right?
YoGMan
Joined Sep 20, 2017
76
The diodes act like switches. see this video for an explanation:
Bertus
Hello Thank you bertus , Im a big fan of EEVblog and I just missed this part where he says ' Assume the circuit has reached a steady state' at 2:30 I can now clarify my doubt ;) - The book also assumes the circuit reached a steady state.
ian field
Joined Oct 27, 2012
6,536
Hello guys
Using electrolytics is less common than smaller non polarised - which you can usually get away with by increasing the frequency.
The input electrolytic can be 2 in inverse series with parallel protection diodes - normally 2 identical capacitors in series gives half the capacitance, but not with the parallel diodes in place.
