Voltage Divider
WBahn
Joined Mar 31, 2012
33,309
The Vin is rated for the 12 V. If it can't operate properly on a voltage input it is rated for, that doesn't say good things about the design.
But it would be better to drop the 12 V using diodes, if nothing else, and use a regulated 5 V output for the sensors.
Jon Chandler
Joined Jun 12, 2008
1,652
Yep, Vin is rated for 12 volts. But a quick search shows that people have had overheating problems when doing so. I can't vouch for the accuracy of those statements, but there are plenty of them around.
Maybe overheating is a myth, maybe not. But apparently this is for a device that has to be reliable over the long term. Buck converter modules are cheap and don't require much real-estate. Seems like it's a prudent step to me. The alternative is to supply 12v to the Arduino and use its on board voltage regulator. If/when it proves to be unreliable others can be blamed for a poor design.
ElectricSpidey
Joined Dec 2, 2017
3,362
Sounds like a typical not accounting for wattage situation.
Poster says: My transistor keeps burning up, it's rated for 60-volts and 1 amp.
Yea, but not at the same time.
Jon Chandler
Joined Jun 12, 2008
1,652
Far more stable is an LM78L05, or a LM7805. Cheaper and simpler.
Cheaper? Pennies perhaps. Mini 360 dc-dc buck converter modules can supply 3 amps and can be had for 36 cents each or less. They may not be necessary for this application drawing 25mA, but they're not going to hurt anything either.
Jon Chandler
Joined Jun 12, 2008
1,652
I have used a number of them without problems. They are a cloned common design with I'm sure tens of thousands in use.
I've made 3 valid points here:
1. A voltage divider should not be considered as a power source. I showed the WHAT – I suggest it's a good exercise to apply Ohm's Law to understand the WHY.
2. I've indicated that some people have encountered problems when an Arduino is powered by more than 9 volts, and that for maximum reliability, a 5 volt regulator should power both the Arduino and external loads.
3. I suggested the a buck dc-dc could be used to cut heating and power dissipation.
Beyond that, I'm done.
