Voltage and Reluctance
peterbosse
Joined Mar 3, 2017
I was taught years ago that an electric motor's horsepower rating was voltage times current divided by 746. I have a new NOVA drill press with a Digital Variable Reluctance motor that can run on 115V or 230V and the HP is shown as 1.75 HP @ 115V and 2.0 HP at 230V. How is that possible? (I don't fully understand variable reluctance).
thanks ~ Peter
Kermit2
Joined Feb 5, 2010
4,162
It's because the torque/voltage relationship is not the same as other motors. The rotor is just a shaped slug of soft iron.
The torque vs voltage plot looks VERY much like the graph of magnetic induction vs current. After you reach a certain strength of magnetism the induction values stop increasing proportionality.
Same for your motor. The voltage doubles but magnetic induction strength doesn't double because it has already reached the "knee" of the linear portion of that response curve of induction vs current.
peterbosse
Joined Mar 3, 2017
Thanks so much! I knew that "something" had to be non-linear, but without knowing much (read nothing) about reluctance in the first place I quickly got lost.
