- Joined Jul 18, 2013
- 30,876
Many are still AC powered.
You are bound to get the battery operated from some vendors.
I see the issue. You are confusing Amps with VoltAmps. They are different measurements and you cannot compare them. 20VA is not 20A! 20VA at 16V is 1.25A which has been explained before.20 Amps!!!
Are you sure? An old 100Watt light bulb only needs 1A! Your car needs less than 10A to start! An electric stove runs on less than 20A!
Possible, but I doubt it!I am not replacing My Doorbell.
I just wanted to know how the Power Rattings work.
So if most Doorbell Transformers are around 30VA back in the 90's do you think a Doorbell Transformer was Rated around 8VA?
Troll alert![]()
Agreed!I was about to post the same!![]()
Did you do the research that I suggested?I am just getting new to all of the Rattings.
So most doorbell Transformer will Step Down the 120 V to 16 V I get this.
And I now know what VA is.
VA is VoltAmps.
So would you Say most Doorbell Transformers are Rated around 20 VA or will they be Lower?
Now, Wireless kind abound!And what would the VA be for a Doorbell Transformer in the 1980's?
After 58+ posts?Ok so I now know a Doorbell Transformer in the Year 2,000 will around 24 Volts and may be Rated 20 V/A.
And this is for USA.
But in the 80's and 90's the Doorbell did not need that Mutch Voltage I thought?
So what Voltage did the Doorbell Transformer Output?
And what v/A was it Rated at?
I’m guessing he either:After 58+ posts?
See other posts, #16 for example, bell transformers haven't changed that much.!
Why the obsession?
