I have the following project created for an Artix-7 FPGA target: xc7a35tcpg236-1
Very straight forward VHDL here is the top module. It instantiates a MMCM IP clock manager that takes the boards 12Mhz clock and converts it to 100Mhz.
The next VHDL module, just blinks an LED via a counter using the 100Mhz clock. This proves the clock module is working.
You will notice I instantiated a Xilinx Microblaze MCS processor in the top module and have one of the port outputs connected to a second LED.
I exported the design to the SDK along with the bit file and built an application project that is also attached. The application project is to blink the second LED.
The source code is just helloworld.c modified to blink the second LED.
The FPGA file builds fine and blinks the first LED on the board proving the 100Mhz clock is present.
I can build the Microblaze application fine as well but when I go to run it, I get the following error:
Error while launching program:
no targets found with "name =~ "microblaze*#0" && bscan=="USER2" && jtag_cable_name =~ "Digilent Cmod A7 - 35T 210328AD3CE8A"". available targets:
1* xc7a35t
1* xc7a35t
Anyone with experience doing this? What am I doing wrong and how to go about fixing it?
Thanks!
1* xc7a35t
1* xc7a35t
Thanks!
