I have a circuit board out of an old microwave oven, complete with the keypad and the display. Notwithstanding, I'm considering using it for some sort of timing function - to be defined at a later date. For now I want to know how to identify the 120 VAC IN side of the transformer. It's likely a step-down transformer and personally I don't care what the secondary voltage is. Whatever it is it's what the circuitry needs to operate. I can just use the relay output as a timed switch, or I can use the countdown feature with an alarm (beep) at the end of the countdown.
Looking at the transformer, underneath the tape covering the windings (and it's not going to be easy to strip away the tape) it looks like the secondary side is a larger gauge wire than the primary side. Of course I'm guessing, and guessing can be a bad thing if you apply the wrong voltage to the wrong side. Since the transformer is "In Circuit" and I don't feel like isolating the secondary side (if what I think is the secondary), taking a resistance reading isn't going to yield any real useful information that I can think of.
So, just by visually observing what appears to be one side of large gauge wire versus the other side of much finer wire - am I right to assume that a step down transformer would have the fine wiring on the primary side?
