Good evening to you all, or whatever time it is where you are
Just a quick question, I apologize if this doesn't fit here, what're your thoughts regarding VIA holes located underneath a coin cell on a PCB? On a through-hole battery holder there is sufficient insulation from the battery holder itself. However, on a 'clip' style coin cell holder there is no insulation between the battery GND and the PCB itself. Would you advise to not have any VIA's underneath it at all, filled vias or exposed?
I've attached an image of the style of holder I'm using.
Thank you,
Sam Matthews.
Thank you,
Sam Matthews.
