I have to implement the following diagram(attachment) in vhdl. When i run synthesis i get warning "[Synth 8-3917] design top_module" has port led3 driven by constant 0 but in the code i didn't connect led3 to be 0. i tried to solve it but no success. When i simulate, the outputs(led0,led1...led3) are always at 0. What i'm implementing is a state counter with control store and address jamming. In this implementation we have to use ic 74161,74244, and 74153.
74161 : http://users.ece.utexas.edu/~valvano/Datasheets/74LS163.pdf
74244 : http://www.sycelectronica.com.ar/semiconductores/74LS244.pdf
74153 : http://www.sycelectronica.com.ar/semiconductores/74LS153.pdf
The codes are as follows. Any help is greatly appreciated.
Top Module
Code:
IC 74161 Implementation
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity ic74161 is
port (
CLR : in std_logic; --Active Low
CLK : in std_logic;
A,B,C,D : in std_logic;
QA,QB,QC,QD : out std_logic;
ENP : in std_logic;
ENT : in std_logic;
LOAD : in std_logic; --Active Low
RCO : out std_logic
end ic74161;
architecture Behavioral of ic74161 is
signal output : std_logic_vector(3 downto 0);
begin
logic : process(CLK,CLR,ENP,ENT,LOAD)
begin
if(CLR = '0') then
output<="0000";
elsif(rising_edge(CLK)) then
if(LOAD = '0') then --**start from here
output(3) <= A;
output(2) <= B;
output(1) <= C;
output(0) <= D;
else
if(ENP = '1' and ENT = '1') then
output <= output + 1;
else
output <= output;
end if;
end if;
end if;
end process logic;
QA <= output(3);
QB <= output(2);
QC <= output(1);
QD <= output(0);
RippleCarryOut : process (output,ENT)
begin
if(output = B"1111" and ENT='1')then
RCO <= '1';
else
RCO <= '0';
end if;
end process RippleCarryOut;
end Behavioral;
Code:
IC74244 Implementation
library IEEE;
entity ic74244 is
port(
X1G,X2G : in std_logic;
X1A1,X1A2,X1A3,X1A4 : in std_logic;
X2A1,X2A2,X2A3,X2A4 : in std_logic;
Y1A1,Y1A2,Y1A3,Y1A4 : out std_logic;
Y2A1,Y2A2,Y2A3,Y2A4 : out std_logic
end ic74244;
architecture Behavioral of ic74244 is
signal y1x1_output : std_logic;
signal y1x2_output : std_logic;
signal y1x3_output : std_logic;
signal y1x4_output : std_logic;
signal y2x1_output : std_logic;
signal y2x2_output : std_logic;
signal y2x3_output : std_logic;
signal y2x4_output : std_logic;
begin
X1 : process(X1G,X1A1,X1A2,X1A3,X1A4)
begin
if(X1G = '1') then
y1x1_output <= 'Z';
y1x2_output <= 'Z';
y1x3_output <= 'Z';
y1x4_output <= 'Z';
else
y1x1_output<=X1A1;
y1x2_output<=X1A2;
y1x3_output<=X1A3;
y1x4_output<=X1A4;
end if;
end process X1;
X2 : process(X2G,X2A1,X2A2,X2A3,X2A4)
begin
if(X2G = '1') then
y2x1_output <= 'Z';
y2x2_output <= 'Z';
y2x3_output <= 'Z';
y2x4_output <= 'Z';
else
y2x1_output<=X2A1;
y2x2_output<=X2A2;
y2x3_output<=X2A3;
y2x4_output<=X2A4;
end if;
end process X2;
Y1A1 <= y1x1_output;
Y1A2 <= y1x2_output;
Y1A3 <= y1x3_output;
Y1A4 <= y1x4_output;
Y2A1 <= y2x1_output;
Y2A2 <= y2x2_output;
Y2A3 <= y2x3_output;
Y2A4 <= y2x4_output;
end Behavioral;
Code:
IC74153 Implementation
library IEEE;
entity ic74153 is
-- Port ( );
port(
sel_A : in std_logic;
sel_B : in std_logic;
X1C1 : in std_logic;
X1C2 : in std_logic;
X1C3 : in std_logic;
X1C4 : in std_logic;
G1 : in std_logic;
--Y1 : out std_logic;
MPC_LOAD : out std_logic;
bit9,bit10,bit12 : in std_logic
end ic74153;
architecture Behavioral1 of ic74153 is
signal output_y1 : std_logic;
signal xor1 : std_logic;
signal or1 : std_logic;
signal temp_out : std_logic;
begin
logic : process(G1,sel_A,sel_B,X1C1,X1C2,X1C3,X1C4)
begin
if( G1 = '1') then
output_y1 <= '0';
else
case sel_A is
when '0'=>
case sel_B is
when '0'=>output_y1<=X1C1;
when'1'=>output_y1<=X1C2;
when others=>output_y1<='X';
end case;
when '1'=>
case sel_B is
when '0'=>output_y1<=X1C3;
when '1'=>output_y1<=X1C4;
end case;
end case;
end if;
end process;
xor1<=output_y1 xor bit12;
or1<= xor1 nor bit10;
temp_out<=or1 nor bit9;
MPC_LOAD<=temp_out;
end Behavioral1;
Code:
Control Store implementation
library IEEE;
use IEEE.STD_LOGIC_ARITH.ALL;
entity control_store is
Port (
addr : in std_logic_vector(7 downto 0);
data : out std_logic_vector(23 downto 0)
end control_store;
architecture Behavioral of control_store is
begin
process (addr)
begin
case addr is
when X"00" => data <= X"000100";
when X"01" => data <= X"020101";
when X"02" => data <= X"040102";
when X"03" => data <= X"060103";
when X"04" => data <= X"081600";
when others => data <= X"000100";
end case;
end process;
end Behavioral;
Top Module
Code:
library IEEE;
entity top_module is
port(
CLK : in std_logic;
PRESENT : in std_logic;
JAM : in std_logic;
sw0,sw1,sw2,sw3 : in std_logic;
led0 : out std_logic;
led1 : out std_logic;
led2 : out std_logic;
led3 : out std_logic
end top_module;
architecture Behavioral of top_module is
--COMPONENTS--
---------ic74161-------------------------------
component ic74161 is
port (
CLK : in std_logic;
ENP : in std_logic;
ENT : in std_logic;
RCO : out std_logic
end component;
---------74244----------------------------------
component ic74244 is
port(
end component;
--------74153------------------------------------
component ic74153 is
port(
sel_A,sel_B : in std_logic;
G1 : in std_logic;
bit9,bit10,bit12 : in std_logic;
end component;
---------control store-----------------------------
component control_store is
Port (
end component;
----------Signal------------------------------------
signal addr_top : std_logic_vector(7 downto 0);
signal data_top : std_logic_vector(23 downto 0);
signal mpc_load_temp : std_logic;
signal RCO_ENT : std_logic;
signal Q1_conn : std_logic_vector(3 downto 0);
signal Q2_conn : std_logic_vector(3 downto 0);
signal vcc : std_logic:='1';
signal gnd : std_logic:='0';
begin
instance1_74161 : ic74161 port map(
CLK => CLK,
CLR => PRESENT,
ENT => vcc,
ENP => data_top(8),
LOAD => mpc_load_temp,
A => data_top(0),
B => data_top(1),
C => data_top(2),
D => data_top(3),
QA => Q1_conn(0),
QB => Q1_conn(1),
QC => Q1_conn(2),
QD => Q1_conn(3),
RCO => RCO_ENT
instance2_74161 : ic74161 port map(
CLK => CLK,
CLR => PRESENT,
ENT => RCO_ENT,
ENP => data_top(8),
A => data_top(4),
B => data_top(5),
C => data_top(6),
D => data_top(7),
QA => Q2_conn(0),
QB => Q2_conn(1),
QC => Q2_conn(2),
QD => Q2_conn(3),
RCO => open
instance_74244 : ic74244 port map(
X1G => JAM,
X2G => JAM,
X1A1 => Q1_conn(0),
X1A2 => Q1_conn(1),
X1A3 => Q1_conn(2),
X1A4 => Q1_conn(3),
X2A1 => Q2_conn(0),
X2A2 => Q2_conn(1),
X2A3 => Q2_conn(2),
X2A4 => Q2_conn(3),
Y1A1 => addr_top(4),
Y1A2 => addr_top(5),
Y1A3 => addr_top(6),
Y1A4 => addr_top(7),
Y2A1 => addr_top(0),
Y2A2 => addr_top(1),
Y2A3 => addr_top(2),
Y2A4 => addr_top(3)
instance_74153 : ic74153 port map(
sel_A => data_top(13),
sel_B => data_top(14),
x1C1 => sw0,
x1C2 => sw1,
x1C3 => sw2,
x1C4 => sw3,
G1 => gnd,
bit9 => data_top(9),
bit10 => data_top(10),
bit12 => data_top(12),
MPC_LOAD => mpc_load_temp
cont_store : control_store port map(
addr => addr_top,
data(16 downto 0) => data_top(16 downto 0),
data(23 downto 21)=>data_top(23 downto 21),
data(17)=>led0,
data(18)=>led1,
data(19)=>led2,
data(20)=>led3
-- led0<=data_top(17);
-- led1<=data_top(18);
-- led2<=data_top(19);
-- led3<=data_top(20);
end Behavioral;
Code:
Testbench
library IEEE;
entity testbench is
-- Port ( );
end testbench;
architecture Behavioral of testbench is
component top_module is
port(
CLK : in std_logic;
JAM : in std_logic;
sw0,sw1,sw2,sw3 : std_logic;
led0,led1,led2,led3 : out std_logic
end component;
--SIGNAL
signal CLK : std_logic:='0';
signal PRESENT : std_logic:='1';
signal JAM : std_logic:='0';
signal sw0,sw1,sw2,sw3 : std_logic;
signal led0,led1,led2,led3 : std_logic;
begin
uut : top_module port map(
CLK => CLK,
PRESENT => PRESENT,
JAM => JAM,
sw0 => sw0,
sw1 => sw1,
sw2 => sw2,
sw3 => sw3,
led0 => led0,
led1 => led1,
led2 => led2,
led3 => led3
CLK <= not CLK after 100ns;
sim1 : process
begin
sw0 <='0'; sw1 <='0'; sw2 <='0'; sw3 <='0';
wait for 700 ns;
sw0 <='0'; sw1 <='0'; sw2 <='0'; sw3 <='1';
wait for 300ns;
sw0 <='0'; sw1 <='0'; sw2 <='1'; sw3 <='0';
wait for 300 ns;
sw0 <='0'; sw1 <='0'; sw2 <='1'; sw3 <='1';
wait for 300 ns;
sw0 <='0'; sw1 <='1'; sw2 <='0'; sw3 <='0';
wait for 300 ns;
sw0 <='0'; sw1 <='1'; sw2 <='0'; sw3 <='1';
wait for 300 ns;
sw0 <='0'; sw1 <='1'; sw2 <='1'; sw3 <='0';
wait for 300 ns;
sw0 <='0'; sw1 <='1'; sw2 <='1'; sw3 <='1';
wait for 300 ns;
sw0 <='1'; sw1 <='0'; sw2 <='0'; sw3 <='0';
wait for 300 ns;
sw0 <='1'; sw1 <='0'; sw2 <='0'; sw3 <='1';
wait for 300 ns;
sw0 <='1'; sw1 <='0'; sw2 <='1'; sw3 <='0';
wait for 300 ns;
sw0 <='1'; sw1 <='0'; sw2 <='1'; sw3 <='1';
wait for 300 ns;
sw0 <='1'; sw1 <='1'; sw2 <='0'; sw3 <='0';
wait for 300 ns;
sw0 <='1'; sw1 <='1'; sw2 <='0'; sw3 <='1';
wait for 300 ns;
sw0 <='1'; sw1 <='1'; sw2 <='1'; sw3 <='0';
wait for 300 ns;
sw0 <='1'; sw1 <='1'; sw2 <='1'; sw3 <='1';
wait for 300ns;
end process;
end Behavioral;
