Very basic quesion about soldering a small circuit board onto a "protoboard"
Roger at CCCC
Joined Jun 8, 2009
17
Very basic question: I have a small circuit board that has headers already soldered onto it. I want to solder these headers to a "protoboard" and then attach other components to the protoboard. However, when I do that the original circuit board is suspended above the protoboard about an eighth of an inch with no support except for the solder joints on the headers. This doesn't seem like a good idea but I'm not sure what to do about it. Is it typical to just leave the original circuit board suspended, assuming that the solder joints can take the very small amount of stress from the weight of the small circuit board? Or is it more typical to put something underneath the small circuit board to support it? But in that case, what's the best thing to use to do that? A picture of the best way to securely attach the small circuit board to the protoboard in this situation would be very helpful. Sorry for the very basic question, but I haven't done this very much. Thanks in advance for any suggestions.
hp1729
Joined Nov 23, 2015
2,304
Since the whole assembly is going to see a good bit of handling I agree with your concerns. Thick two-sided tape or a glob of silicon sealer maybe?
dl324
Joined Mar 30, 2015
18,396
Male or female headers? Lead length? Size of the small circuit board?
Post pictures.
Use paragraphs.
FWIW, I have used female header strips to mount "daughter" boards with male headers (wirewrap strip in this case). The board is around 1.5"x2".
Roger at CCCC
Joined Jun 8, 2009
17
Thanks for your comments. I've attached a picture above of what I am trying to do. In the picture, the small circuit board is on the right with male headers pointing downward. The Protoboard is on the left. The question is: do I need to do something to support the small circuit board so its weight doesn't rest only on the solder joints? (I haven't soldered the headers to the Protoboard yet.) Sorry for the amateurish look. Thanks again for any suggestions.
ronv
Joined Nov 12, 2008
3,770
It might be alright if it were not cantilevered out like that. To add insult to injury it looks like it would get a lot of handling due to the sockets and plugs.
KL7AJ
Joined Nov 4, 2008
2,229
I've done precisely that many times. Keep in mind that the proto board is just that. It only had to hold together long enough for you to get the circuit designed. :)
dl324
Joined Mar 30, 2015
18,396
If you mount both boards to another board, you can support with spacers and/or standoffs.
In this example I made a support from copper clad and tacked to the bottom of the board to support it.
SLK001
Joined Nov 29, 2011
1,549
For short term evaluation of a design, it will probably be okay. However, since there at least two connectors that I can see, if this is a long term endeavor, then fill the space under the board with GOOP or something. A solder joint isn't very reliable when there is no mechanical support for it - especially with constant handling.
hp1729
Joined Nov 23, 2015
2,304
A rubber foot for something less permanent?
Alec_t
Joined Sep 17, 2013
15,125
Stuff a block of styrofoam into the gap? Or do you have space on both boards to drill and put a bolt through them?
ErnieM
Joined Apr 24, 2011
8,415
What Alec t said. For proto work I will oft use long screws and lots of nuts to secure a long screw to the base and then use a pair of nuts to hold the flying board.
