Vero board design for circuit diagram
rasikac
Joined May 11, 2018
8
Hi,i want to simplyfy the veroboard disign for attaced circuit diagram or software to design
ericgibbs
Joined Jan 29, 2010
21,570
hi rasikac,
Welcome to AAC.
Do you have an existing vero board design image you could post, that we can suggest simplifying .?
E
jpanhalt
Joined Jan 18, 2008
11,087
I just use Eagle (mine is pre-version 8.0), set a 0.1" grid, make a rough outline of the strip board, and do routing in the usual manner, except there are no diagonals. I also use an X to denote either an implied connection that isn't or a cut in a trace. You might want to use top layer for existing copper traces and bottom for connecting wires. I use Kynar 24 awg for connections. Kynar is easy to strip, the insulation is thin, and it doesn't char or shrink back with normal soldering.
Here's a section of a board that was laid out that way:
The thing I like most is schematic capture. That way, you can be sure all connections are made and there are no wrong ones.
John
shortbus
Joined Sep 30, 2009
10,049
Hi, would you share what brand that board is, please? Or where it came from? I'm trying to make a circuit and that type of board would be ideal for what I want to do. All of the vero/strip boards I've seen just have the copper going from one edge to the other. I like the way that board has a center section going perpendicular to the edges.
jpanhalt
Joined Jan 18, 2008
11,087
I don't remember exactly. I got that version quite awhile ago. Nice, but not through-hole plated. It may be an early version from BusBoard.com (http://busboard.com/products).
More recently, I have gotten virtually identical boards with plated holes from that vendor . Specifically, its SB4 Snappable PC BreadBoard. I have also used the boards from SparkFun. They sure are nice for anything that is not just for a quick experiment.
Note that with the SF board #30 (small), the supply rail holes are staggered relative to the columns for devices. Therefore, I have to make a little hook on resistors and such so they line up to my satisfaction. ;)
The large SF board device does not have that "feature" and everything lines up nicely. It also has connections at the end for the supply rails. A #30 drill (preferably 135° angle, but 118° is OK) works great for cutting tracks and removing a plated pad. For just cutting a track between holes, I use a tiny burr in my Dremel.
rasikac
Joined May 11, 2018
8
You can not link images to your local harddisk.
Please upload the image to the forum.
Bertus
please check,i attached the file
hi rasikac,
Welcome to AAC.
E
Moderators note : removed double pictures.
ericgibbs
Joined Jan 29, 2010
21,570
hi,
I would say your layout around the IC is OK.
The rectifier diodes and smoothing caps could be moved closer to the IC group.
Which part of the PCB layout do you think needs reworking.?
I assume the PCB and circuit does actually work.?
E
rasikac
Joined May 11, 2018
8
hi,
E
Yes .Its ok.
ericgibbs
Joined Jan 29, 2010
21,570
hi r,
Your posts are not giving us enough information to work with.
