Terminal block connectors on a vero board
Dija Angel
Joined Oct 1, 2021
33
Hello I was wondering if you could connect components in the same row as a terminal block in the copper tracks on a vero board and if you can use it as a ground and power for your components?
ericgibbs
Joined Jan 29, 2010
21,622
Hi Dija,
I often use those TB's in that way, low voltage DC or AC.
E
ericgibbs
Joined Jan 29, 2010
21,622
hi D.
I am not sure what you mean by a single terminal block?
Do you mean just using one of the two possible connections.?
E
Dija Angel
Joined Oct 1, 2021
33
hi D.
E
Hello!what I mean is that im using just one terminal block with one row for power and one row for ground like this in the picture so for the row for power do I connect components that need to be connected to power in only that row and do the same for the ground?
35,270
That is a 2-position 5.08mm pitch screw terminal block.
Once you manage to mount and solder it on to the strip board, you can connect to the copper tracks however you please, assuming that you do not exceed the current carrying capabilities.
You may add jumpers from one track to another if you need to connect to other parts of the board.
Dija Angel
Joined Oct 1, 2021
33
Thank you so much
ericgibbs
Joined Jan 29, 2010
21,622
hi D,
What sort of components are you considering.?
Do you have a circuit that you want to build on strip board, if yes, post the circuit and we can give better advice.
E
35,270
What component would you use?
Why use another component when a jumper wire cost you almost nothing?
Maybe we do not understand what you are trying to do.
Use fritzing to show us what you are trying to do.
BobTPH
Joined Jun 5, 2013
11,665
If you mean: “Can I solder one lead of a resistor directly to the same track as the terminal block?” The answer is yes, of course.
Bob
35,270
Thank you but can I do it with a diode too?
You can do whatever you please as long as it replicates the circuit design.
Take all your components of the circuit and temporarily insert them on the strip board. Then take a photograph and we will guide you from there on.
Dija Angel
Joined Oct 1, 2021
33
Alright thank you guys so much for all your help I appreciate it x
