I got this vero board today. Can somebody tell me how to cut this board in smaller pieces?
L Thread Starter lichurbagan Joined Jul 4, 2025 137 Aug 3, 2025 #1 I got this vero board today. Can somebody tell me how to cut this board in smaller pieces?
ElectricSpidey Joined Dec 2, 2017 3,358 Aug 3, 2025 #2 For me personally it would be either score and snap or my bandsaw.
MaxHeadRoom Joined Jul 18, 2013 30,808 Aug 3, 2025 #4 For small widths, I use a Junior Hacksaw, for wider sections a dremel with cut off disc. Smooth the edge with sander.
dl324 Joined Mar 30, 2015 18,465 Aug 3, 2025 #5 lichurbagan said: I got this vero board today. Can somebody tell me how to cut this board in smaller pieces? Click to expand... I'd use my 8" metal shear from Harbor Freight: If I didn't have it, I'd probably score and snap. Line up the score with the edge of a table to snap. Or use a metal bending tool: Last edited: Aug 3, 2025
MrChips Joined Oct 2, 2009 35,177 Aug 3, 2025 #6 This is what I would call Veroboard or stripboard. It is easy to score and snap. I score in line with the holes. With fiberglass perfboard, I would use a fine saw or metal shear. A heavy duty paper cutter also cuts stripboard, perfboard, and copper clad laminate.
M MisterBill2 Joined Jan 23, 2018 28,272 Aug 3, 2025 #7 I choose to use a fine (32 TPI) pitch hacksaw blade if I am cutting a section witha project already built on it.
MaxHeadRoom Joined Jul 18, 2013 30,808 Aug 3, 2025 #8 I mostly use Vero board and the best way to detect 'Whiskers' between solder points on adjacent tracks, is to run a box-cutter blade between the tracks, Detects even the slightest whisker.
BobTPH Joined Jun 5, 2013 11,647 Aug 3, 2025 #9 I use diamond disk on my micro table saw. Very clean cuts.
