VCNL4040 sensor C programming library with Raspberry
guetkar
Joined Mar 9, 2022
35
I'm using the VCNL4040 sensor (of Vishey) with Raspberry Pi 3B+, in python there is a library named "adafruit_vcnl4040", that we can import and use it. Since I'm codding it in C, it's not possible to use the same library, on the other side I didn't find any library that can be used in C (to save time and avoid developping it from scatch).
Does any know any library, or an already done script that can be used in C ?
Thank you
Karim
