VCNL4040 sensor C programming library with Raspberry
guetkar
Joined Mar 9, 2022
35
I'm using the VCNL4040 sensor (of Vishey) with Raspberry Pi 3B+, in python there is a library named "adafruit_vcnl4040", that we can import and use it. Since I'm codding it in C, it's not possible to use the same library, on the other side I didn't find any library that can be used in C (to save time and avoid developping it from scatch).
Does any know any library, or an already done script that can be used in C ?
Thank you
Karim
FlyingDutch
Joined Mar 16, 2021
73
Thank you
Karim
there is library in C++ for Arduino - see links:
https://www.adafruit.com/product/4161
https://learn.adafruit.com/adafruit-vcnl4040-proximity-sensor/arduino
and here is API for this C++ library described:
https://adafruit.github.io/Adafruit_VCNL4040/html/class_adafruit___v_c_n_l4040.html
Best Regards
FlyingDutch
Joined Mar 16, 2021
73
Hello @guetkar ,
C or C++ is basically portable from platform to platform. Of course in C++ source could be fragments that are hardware specific, but you shoukd to analyze this code and try to rewrite it for new platform. In code of such library you could find parts that are responsible of sensor behaviour. I would feel lucky if I have C++ source of library for this sensor.
Best Regards
