Variable power supply help!
mally
Joined Feb 4, 2016
36
Hello guys just to let you know i have managed to get this power supply working. In one of the earlier post's (#10) the video i mentioned that the circuit board was almost exactly the same as the one i have apart from some on the diodes where the opposite way round . so today i watched the video again and paused it as he was looking at his circuit board and the tracks and everything else was the same apart for some diodes , so with that (and the fact i was at a dead end with it) i decided to change the diodes and make the as the one in the video . and hey presto it worked.(all can say the printed board is wrong) Well i am still got my input as 20vac (it states 24vac but its all i have for now) but the power out i get fro 0v to 25vdc. Is this because i need 24vac input ? i have put some pictures and ringed the diodes i have turned around and some pictures of the printed board after i removed the diodes too .
mally
Joined Feb 4, 2016
36
dl324
Joined Mar 30, 2015
18,445
Do you really expect us to read a post like this?
Try using paragraphs and proper grammar.
mally
Joined Feb 4, 2016
36
Sorry Dennis .
Hello, Just to let you know i have managed to get this power supply working. In one of the earlier post's (#10) the video i mentioned that the circuit board was almost exactly the same as the one i have apart from some on the diodes where the opposite way round .
So today i watched the video again and paused it as he was looking at his circuit board.
The tracks and everything else was the same apart for some diodes , So with that i mind (and the fact i was at a dead end with it) I decided to change the diodes and make it as the one in the video , And hey presto it worked.
Well i am still got my input as 20vac (it states 24vac but its all i have for now) but the power out i get from 0v to 25vdc.
Is this because i need 24vac input ? I have put some pictures and highlighted the diodes i have turned around and some pictures of the printed board after i removed the diodes too .
Craps1956
Joined Aug 21, 2015
38
Hi mally
I know that a long time has passed, but I have just seen you post today. If you are still interested I have the manual and circuit schematic for your power supply. There are a lot of problems with that circuit. I also have an update that fixes all the problems. I have assembled the updated 3A version and it works perfectly. Can easily be modified to 5A output. Can post all if you want.
dl324
Joined Mar 30, 2015
18,445
Sorry for the late response. I didn't get a notification until someone reincarnated the thread...
The voltage you'll be able to get could be reduced by as much as 1.414*4.
