Vaccum pump control Help please
Alvin0119
Joined Dec 13, 2018
Hi, I'm after a circuit design for a vacuum pump control, I need it to pull 4hg with pressure peaks of up to 10hg , unsure on how to design it, very new to this. All help is appreciated. Thanks in advance.
wayneh
Joined Sep 9, 2010
18,164
We'll need a lot more details and context. Why are you doing this - what't the situation and the goal? What are the details of the pump such as voltage, current requirements? Do you need a feedback loop, so that something about the pump operation depends on a vacuum sensor?
LesJones
Joined Jan 8, 2017
4,543
I would guess it some unspecified units of height of a column of mercury. (But I think you will have also made the same guess and I also think you will have guessed the same as me that the unit of distance is mm,) I am surprised that his teachers have not drummed into him the importance of specifying units rather than just a number,
Les.
jpanhalt
Joined Jan 18, 2008
11,087
Les.
There is an important difference between torr (mm Hg ) and microns -- at least in my experience. The former can use a simple TC (thermal conductivity) gauge. The latter needs something like a vacuum tube ("ionization") gauge.
jpanhalt
Joined Jan 18, 2008
11,087
Vacuum units are a strange mashup of related units. Pascal is the offical SI unit but most of the US industrial (high-vacuum physics and engineering) high vacuum units display in mTorr (millimeter of Hg).
In my experience years ago, a Torr was a mm of Hg, and we commonly expressed the pressure as an exponent of Torr, e.g., 10^-6 Torr. Didn't use the "mashup" of mTorr.
joeyd999
Joined Jun 6, 2011
6,456
Vacuum units are a strange mashup of related units. Pascal is the offical SI unit but most of the US industrial (high-vacuum physics and engineering) high vacuum units display in mTorr (millimeter of Hg) or Torr.
https://www.mksinst.com/product/Category.aspx?CategoryID=525
Even worse: many commercial/scientific instruments use mbar as the basic unit of vacuum measure.
And the operators/technicians/scientists don't even refer to the units in communications:
"Hey, Jim, what's the vacuum level right now?"
"Oh, about ten to the minus five..."
Simply maddening.
Normal US SEMI practice is to use the mTorr (old school microns) mashup with rough vacuum as it gives nice scaled (0 to ~1000 max) numbers on a display gauge in the pumps operational range and then switch to exponent notation in high vacuum where the decade is the main scale of vacuum quality.
