Hi all,
I need a circuit for converting voltage to frequency using AD537JH. Here voltage is my input signal to the ad537jh and output is in the form of frequency. When ever input voltage is zero then the AD537JH should give 10khz frequency. If the input voltage is at maximum (i.e +Ve) AD537JH should give 15khz, similarly if input voltage at minimum( i.e. -Ve) AD537JH should give 5Khz. Therefore could you suggest me the circuit diagram with AD537JH(H-10A metal cap package, 10-Pin). I have followed the datasheet. But didn't get my output, please do not suggest other V to F converters because I have already purchased AD537JH.
