Utilize lm317 bandgap reference with minimal current?
k1ng 1337
Joined Sep 11, 2020
1,038
Good Day,
How can I use the internal bandgap reference of a lm317 as an input for a comparator using the least current possible?
Currently I am using the voltage regulator configuration of the lm317 to provide 1.4v at out as seen in the attached image but this requires a load resistor which draws a significant amount of current (~1ma) for stability.
I found one post that said to ground the adjust terminal and take the reference at out but this gives me a voltage of VCC - .7
dl324
Joined Mar 30, 2015
18,472
You can't because there doesn't seem to be one.
LM317 aren't guaranteed to work with less than 10mA for the load plus reference current.
k1ng 1337
Joined Sep 11, 2020
1,038
I'm pretty sure this is, I have seen an internal diagram that indicated the reference part of the circuit.. I'll try to locate it
I could be mistaken but then how does the chip establish a temperature independent reference?
k1ng 1337
Joined Sep 11, 2020
1,038
Furthermore the lm317 reference is a nominal 1.25 which corresponds to the bandgap of silicon.
38,827
You need to load the output with at least 10mA (120Ω).
If you need a low current reference than use one of the low power shunt bandgap references,
For example the MAX6007B will operate down to 1μA.
