I need to use a 10W 1 Ohm resistor in a circuit. The problem is that the only kind that I can find are too big (ceramic wirewound through-hole).
My PCB is surface mount and I want to be as small and compact as possible. I am wondering if I can use two smaller surface mount resistors instead of the ceramic wirewound and if it will save me some space?
Also, is it better to wire two resistors in series or parallel when replacing a single resistor?
Thanks
Thanks
