Using transistors to increase the voltage with grounded emitter
ericgibbs
Joined Jan 29, 2010
21,502
hi Phil,
I have found that 10mA or 15mA is sufficient segment current for good 'readability'.
Have you finalised the Driver IC type.?
E
ElectricSpidey
Joined Dec 2, 2017
3,345
You did say you have common anode displays, right?
The MAX7219 is designed to directly drive common cathode displays.
In order to interface the MAX7219 with a common anode display you will need inverting high side drivers at the digit side, and inverting low side drivers at the segment side.
So the ULN2003 should work on the segment side, but the UDN2981 does not invert so you will need to invert the digit side before the drivers, or find inverting high side drivers.
If I’m wrong please feel free to correct me, because it’s kind of hard to get a complete picture without a diagram, and I don’t want to mislead you.
djsfantasi
Joined Apr 11, 2010
9,237
You got it! The TS has already identified the displays as common anode in response to an earlier post of mine. And Sensacell also identified the ULN2003 as the chip to drive the segments.
Philatphil
Joined May 10, 2019
15
OOPs!! The high side is OK now i think but we need a need a positive signal from the MAX7219 for each segment. Maybe I can find a version of the MAX7219 with designed for common cathode or as you say an inverter could be found.
Phil
Philatphil
Joined May 10, 2019
15
What about using a second transistor array to invert the signal all on the low side
Phil
ElectricSpidey
Joined Dec 2, 2017
3,345
“What about using a second transistor array to invert the signal all on the low side”
I don’t see how.
I think you may be stuck using discrete PNPs at the digit side.
Philatphil
Joined May 10, 2019
15
I don’t see how.
I think you may be stuck using discrete PNPs at the digit side.[/QUOTE
The MAX7219 is producing a positive signal for each segment to the UND2981 which is directing each segment cathode to ground so it should work unchanged or there is something I am not seeing.
ElectricSpidey
Joined Dec 2, 2017
3,345
“The MAX7219 is producing a positive signal for each segment to the UND2981 which is directing each segment cathode to ground so it should work unchanged or there is something I am not seeing.”
Yes, what you are not seeing here is that the UDN2981 cannot direct anything to ground, because it is a high side driver. (non-inverting high side driver) (positive in-positive out)
The ULN2003 will direct the segments to ground. (inverting low side driver) (positive in-negative out)
Philatphil
Joined May 10, 2019
15
Thank you . I was misinterpreting the UNL2003 design
