I am scratch building a model of the Dryden Shuttle MDD which includes a lot of LED's as I want to depict it fully lit at night.
I have two towers with 54 LED's, and a horizontal gantry with some others which I have yet to work out. I will be wiring the LED's for a tower as 4 parallel strings of 12 with a 220 ohm resistor for aach string powered by a 45v DC source, the extra 6 LED's, I have yet to think about (they will be red rather than white).
There are other LED's scattered else where such as on telegraph poles etc. Each tower or other set of LED's will have it's own power source which gives me 6 or possibly 8 separate circuits, some may have different source volts but most will be 45v DC.
To turn this lot on and off I would like to use DC SSR's, 3v switch with a max load of 60v, powered by a 2032 coin cell. Is it sensible to wire the SSR's in series ie in- to in+ of the next SSR while connecting the load to different circuits or is there a better way of going about this?
Thanks and regards,
Rich
Thanks and regards,
Rich
