- Joined Jan 23, 2018
- 28,240
Recall that the signal from the RC receiver IS NOT THE PWM we are familiar with. It is a string of a sequence of pule width encoded data. So using it is a bit more complex. THAT is why I made my suggestion.
You are correct. The R/C PWM system really is pulse width modulation (1.5 to 2.5mS) of a series of pulses in a fixed frame rate (18mS). What we refer to as PWM to control motor speeds is actually pulse proportion modulation (PPM).Recall that the signal from the RC receiver IS NOT THE PWM we are familiar with. It is a string of a sequence of pule width encoded data. So using it is a bit more complex. THAT is why I made my suggestion.
