Using one H-bridge to drive 3 motors
Dritech
Joined Sep 21, 2011
907
Hi all,
Is it possible to drive 3 separate motors using one H-Bridge?
I was thinking of doing something as shown in the attached schematic, but is there something more reliable and efficient?
(Note: Max. current will be approx. 25A)
MikeML
5,444
If you are going to use relays to select the motors, why do you even need the Hbridge in the first place? Just do the reversing/selecting with relays...
Even if you need to PWM, you can do that with a single transistor (preferably MOS) switch; use the relay for reversing.
Alec_t
Joined Sep 17, 2013
15,127
With your circuit all active motors would have to rotate in the same direction at any one time. Is that what you want?
Dritech
Joined Sep 21, 2011
907
The motors will not be operating at the same time, so that would not make a difference for my application.
Is there a type of electrical switching device that can drive approx. 25A in both directions?
30,699
Are you controlling the RPM or just on off?
Particularly if you are just on/off you should have some means of detecting stopped motion before reversing.
MikeML
5,444
What are you driving the Hbridge(s) from?
An MCU?
What is the MCU supply voltage?
How much drive on the port pins?
How many port pins can you allocate to driving the motors?
What is the supply voltage at the top of the Hbridge?
Can you use FETs instead of BiPolars.
Dritech
Joined Sep 21, 2011
907
An MCU?
-H-bridge is going to be driven from a PIC18F
-5V
-I want to reduce the amount of port pins to be used as much as possible.
-Supply voltage for the H-bridge (hence to the motors) is 12V
-As an H-bridge I am going to use the BTS7960 (2PCS)
I don't want to use three separate H-bridges for two reasons; to reduce cost (since the BTS7960 are not that cheap) and to reduce the number of PIC18F port pins required to drive the three motors.
MikeML
5,444
Since you are hung up on using the Half Bridges, the relays are the best bet. It takes three port pins to control the two half-bridges (the enable signal can be shared), and two port pins (if you use an external two-to-four line decoder) to select the motors.
You will have to program some serious delays in the code to take care of reversing a single motor, and other delays when selecting a different motor.
