Using IR Module as DC Motor switch
andi.aditya
Joined Feb 23, 2021
5
I'm having a problem with my project. I try to use the IR module as a switch to my DC motor. Basically what I try to do is turning on my motor when the IR module facing an obstacle and vice versa. Components that I use in this project are:
1k Ohm Resistor
TIP122 Transistor
1N4007 Diode
IR Module
12V DC Adaptor
DC Motor
My schematic looks like this:
My problem is that in my end result my DC motor is turning on when there are no obstacles and turning off when facing obstacles. What should I do so I can achieve the opposite (turning on when facing obstacles)?
Thank you for your help :D
ericgibbs
Joined Jan 29, 2010
21,622
hi aa,
Welcome to AAC.
Your drawing is 'confusing' in its layout, I have tried to modify the layout.
What is the output voltage of the PIR when it 'sees' an object and when it does not see an object.?
Is this a school project.?
E
andi.aditya
Joined Feb 23, 2021
5
Hi, e,
Thank you for correcting my layout.
First I need to address that I'm not using PIR sensor, but rather an IR module that I bought in an electronic store that looks like this:
For the output, I guess it's High when it 'see' an object, since the LED indicator shine brighter when I put object in front of it. This is not a school project, I just tried to copy the tutorial about automatic water tap in internet, but I replace the solenoid valve with DC pump. It looks like this:
ericgibbs
Joined Jan 29, 2010
21,622
hi aa,
It is important confirm this, also measure the actual voltage with a meter.
E
andi.aditya
Joined Feb 23, 2021
5
Hi e,
I was wrong. I check the voltage of the output pin using a multimeter, it reads 5.4V when there is no object and 0.7V when it "sees" object
ericgibbs
Joined Jan 29, 2010
21,622
hi, aa,
When in doubt always check the the circuit with a testing device. ;)
To change the low to high, use a transistor connected as an inverter, do you know how to do that.?
E
andi.aditya
Joined Feb 23, 2021
5
Hi, e,
Unfortunately, I don't know how to do that, this is my first time with electronics. I tried to look it up for a while, so basically I need another transistor (MOSFET, I believe?) in addition to my TIP122? Where should I place that transistor in my layout?
andi.aditya
Joined Feb 23, 2021
5
hi aa,
Look at this option.
You could use a low power N MOSFET in place of the 2N2222 type, say a 2N7000.
EView attachment 231264
Thank you very much, E! I'll try this and give an update as soon as possible
Quick note, the TIP122 is NPN and so is the 2N2222.
Hi MrAI, I don't quite understand the NPN thing. What will happen since both TIP122 and 2N2222 are NPN transistors?
MrAl
Joined Jun 17, 2014
13,858
It was just that the two transistors were dawn as PNP when they are really NPN, but Eric posted a new schematic after that with the correct symbols. Just wanted to try to avoid confusion for readers.
peterdeco
Joined Oct 8, 2019
484
Quick question about this circuit. The TS stated the output is 5.4V and drops to .7V when it "sees" an object. Wouldn't the .7V continue to keep the 2N2222 in an on state?
MrAl
Joined Jun 17, 2014
13,858
It could it depends on the gain and other characteristics of the transistor.
It is not something i would want to see though, i would use a base emitter resistor too to bring that down to at least half that or less. 0.3v is probably ok but 0.2v better.
