geekoftheweek
- Joined Oct 6, 2013
- 1,429
It's starting to look like I may have been a little wrong in my thinking on the capacitors. This is one time I want to be proven wrong actually. I hope it works out.
My order of capacitors was just delivered. I'll give it a shot tonight and see how it goes! Thanks for the input!I would think all you need is to find the battery wires put a 100 uf and feed them with 3.7 volts from the usb the cap would hold a little charge to look like there is a battery there but it would boot and run off the usb and think its charging most of theses will run if they have a little bit of battery charge
My LG takes like a second to boot with dead battery Ai said you need a cap with 8.33 mA of charge in it The 100 uf would be more then you probably need
Testing tonight. I'll post an update on how it works. I have my Onn tablet ready and the Samsung Xcover6 Pro with the terminals all set.It's starting to look like I may have been a little wrong in my thinking on the capacitors. This is one time I want to be proven wrong actually. I hope it works out.
