geekoftheweek
- Joined Oct 6, 2013
- 1,429
I was hoping there was some clues... I've been lucky before with them manuals. I poked around on the internet as I'm sure you have and couldn't come up with any decent information. I'm guessing it's a hall effect and with any luck it will be a nice 5 volt square wave. The scope will let you know. Good luck!!Thank you for your kind help. I've looked in the Haynes manuals, but the VSS output signal is not discussed in sufficient detail to build a mechanical speedometer drive. I'll try the oscilloscope today to read the signal if the rain doesn't spoil it!
