originally the electronic term "chopper" described a mechanical switching device used to convert low level signals into AC signals so that they could more easily be amplified. It seems like servo systems used choppers in that era. It had to be the early sixties,because better transistors quickly ended the technology.A quote from the product description of the “chopper”, which is actually an inverter, that you linked to.
Bob
I certainly remember the bike reference. As a Norton Commando 850 user in the 70s I wouldn’t consider ‘chopping’ itoriginally the electronic term "chopper" described a mechanical switching device used to convert low level signals into AC signals so that they could more easily be amplified. It seems like servo systems used choppers in that era. It had to be the early sixties,because better transistors quickly ended the technology.
There was a cartoon type advertising comic strip with characters Anna, Log, and bad-guy Spike. Don't recall which company they were advertising or even exactly what the product was.
After that era "Chopper" referred to custom chopped motorcycles and helicopters.
Ok. I think I need to wait till it arrives and then I will put the output on my scope and see what the waveform actually is. The details say it has various outputs so I should be able to play around till I get the right DC output.Yes, that circuit is right.
Now looking at the image of the waveform, if the line through the middle is zero volts, then it is 840 volts peak to peak. So I am hoping that the waveform drawing is wrong.
But now, once the wave is rectified and used to charge a capacitor , switching the voltage on and off to provide pulses will not be terribly complex, except that the switching circuit will need to operate far above the zero-volt level. AND it is important to know the required rise and fall times of those pulses, as I mentioned before. Millisecond, microseconds, or faster, rise and fall time makes a great deal of difference in how the switching is done.
Ok thanks.It all depends where the reference for this voltage is.
If those voltages are referred to ground (as is inferred by the dotted line through the middle) then you will get 840V output.
If they are measured on one of the output wires referred to the other wire then you will get 420V.
Make sure that the scope probe will withstand the voltage.Ok. I think I need to wait till it arrives and then I will put the output on my scope and see what the waveform actually is. The details say it has various outputs so I should be able to play around till I get the right DC output.
It’ll probably arrive early Jan. Thanks
Good point. Mine is 400V max I think but I can use a simple voltage divider to take the source voltage down by a factor of 10 or so. Same as I used to measure 2200V back emf pulses.Make sure that the scope probe will withstand the voltage.
Yes that will be fine.Good point. Mine is 400V max I think but I can use a simple voltage divider to take the source voltage down by a factor of 10 or so. Same as I used to measure 2200V back emf pulses.
