Using a potentiometer as a run timer
irozak
Joined Apr 3, 2015
28
I want to code an UNO with a simple control where I can turn a knob (the timer), then press a button which starts a stepper motor (speed will be hard-coded). The knob determines the run time, which will be somewhere between 0-10secs. Then the motor will stop and wait for the next push of the button. So I am guessing a potentiometer of some sort but which one? There are millions to choose from. Any assistance greatly appreciated.
Alec_t
Joined Sep 17, 2013
15,158
Unless you want very fine control of the run time a single-turn pot is ok. For fine control, a multi-turn pot might be better.
