MaxHeadRoom
- Joined Jul 18, 2013
- 30,672
I integrated one using the serial interface, supposedly it is Modbus but far from it, the manual does not even mention any of the codes, at least not the one I had.Late last fall I got one of the Huanynag "clones", haven't needed support, but the manual was pretty good, almost English, not the normal "Chinglish" with most stuff. I say "clone" because it isn't branded Huanyang.
I got the info I need from someone who had reverse-engineered it on the Mach forum.
Most VFD's have the same features, run from the front panel or set for external with potentiometer and P.B.'s/SW etc.I'm hoping somebody can pass a comment on how this would work with my motor.
He tells me it is reversible and the variable speed works fine and it will accept a stop start foot control with some extra external work.
There is also an option for a series of pre-set speeds if needed, so they are fairly flexible to integrate.
The parameters are set from the front panel in order to set the motor characteristics etc. No. of poles etc, (4 in your case).
Max.
