What I am trying to achieve:
I am trying to use an Arduino nano with a Monster Moto Shield To drive 2 of these 6 Amp fans, As they are 12v fans and I want to drive two of the 6 amp fans I figured I would require at least a 12 amp PSU, After a while searching I could not find a cheap(ish) 12v 12amp PSU but someone recommended that I could use a 12v 30amp PSU.
What I need help with:
First of all I was wondering what gauge wire I need to wire between the PSU and the Motor shield (12 amp), and what gauge wire I would need to wire between the motor shield and each fan (6 amp) I estimate that it would be something like 10-12 AWG but i would appreciate a second opinion. I also wanted to make sure that with the PSU I would get a mains plug with a cable and splice the cable into the relevant live neutral and ground terminals on the PSU. I was also wondering if the power supply is already fused or if I would need to fuse the plug, If there is a fuse in the power supply would it also be a safe decision to put a fuse into the plug to add extra safety. Also what fuses should I use as the PSU is 30 Amps but I am only requiring 12 amps.
Sorry for making the post a very long post, I just want to make sure I am on the right track and keeping myself safe when near electronics.
Any help would be really appreciated, Thank you in advance.
