So basically it's a 3.5:1 ratio, so if the DC motor is spinning @1000 RPM, the Alternator in theory should be 3500 rpm.
S terminal: If the White wire can reach from the regulator to back into the alternator, you can just use a Female 1/4" (0.250") quick connect and be done with it for now.
A Terminal: You can tie that into the 5/16" output terminal on the alternator itself if you want, since that's more/less a voltage sense that should go to as close to the batteries positive post as possible. (good for voltage drop through terminals, ect), Add fuse if you like, but that short of a distance isn't truly needed!
I terminal: A 1157 bulb may not work, unless you have it wired to the lower output (5w) filament, since most idiot lights on a dash are 5W or less.
The 5/16" output i think you know, and grounding the case to the to negative side of the battery.
If you want to see if the alternator is producing power may be able to start up the system without the alternator to battery positive wire connected, and measure that wire itself?? I know disconnecting the battery when a car is running can have bad side affects (voltage spikes, ect) but disconnecting the alternator from the battery?
