- Joined Jan 23, 2018
- 28,306
To work as a switch, for the 2N2222, the collector goes to the more positive part of the circuit, which in this case is the negative side of the fan motors, since the positive side of the motors connects to +12 volts, and then the emitter connects to the zero volt side of the 12 volt supply. And the base positive bias to switch on is applied to the base, with the return of that bias tied to the emitter, at the common zero volts line.Thanks for all the thoughts. As many posted, you may be right, I think I have the 2N2222 reversed, so will give that a look. Thanks for that catch. Also will confirm my resistors are all connected for the 860 ohms (330, 330, 200) - I’m pretty sure I tested that series for overall resistance when building tho.
For reference, the ESP NodeMCU can put out 3.3v at around 12mA.
Will assess when home in a bit, and digest all the feedback more carefully, thanks.
