USB Lighting
rickbadley
Joined Mar 12, 2020
5
I am a hobbyist wishing to put two LED mini lights in an ornamental project. The USB supplied output power is 5 volts. The mini LED's available are a choice of either 3 volt or 6 volt. Which should I use?
Audioguru again
Joined Oct 21, 2019
6,826
Nobody makes an LED with a voltage as high as 6V, maybe it is two 3V LEDs in series or a 3V LED in series with a current-limiting resistor. Two 3V LEDs in series might not light up when fed only 5V.
An LED is fed a limited current, not a voltage. A series resistor changes the voltage into a limited current.
Please post a link to the sales sheet or datasheet for the LED mini lights.
dl324
Joined Mar 30, 2015
18,476
We need more information. No bare LEDs are available to operate at 6V, and none are exactly 3V.
What color are the LEDs? Do they have integral current limiting resistors?
rickbadley
Joined Mar 12, 2020
5
Thank you Dennis, I will take a different approach and connect led strips made for USB connection.
rickbadley
Joined Mar 12, 2020
5
Will rethink thanks and use USB to LED strip lighting. They are to go inside large seashells.
dl324
Joined Mar 30, 2015
18,476
Do you really want them to require a power adapter? My Wife has a half dozen LED candles on the fireplace mantle and piano. It'd be a big pain if they needed power routed to them.
rickbadley
Joined Mar 12, 2020
5
Yes, the project involves the need for automatic timer on and off scenario thanks.
dl324
Joined Mar 30, 2015
18,476
The timer in the LED candles is pretty simple. In the timer mode, they turn on for several hours (maybe 4), then turn off and turn on again 24 hours after they were first turned on.
They have a microcontroller and operate from 2 AA batteries.
rickbadley
Joined Mar 12, 2020
5
Thanks Dennis, that is an option then and perhaps quite a good one. I shall have a look thank you.
