uP clock signal levels
cferry77
Joined Jun 9, 2018
6
Hello members-
Recently Oscilloscoped the X1 and X2 Clock Input of a special purpose microprocessor within one of main control boards of Tascam Cassette Deck.
The signal level on one ( X1 or X2 ) was a nice sinewave with accurate enough frequency, however , the voltage High and Low levels appeared questionable. The other X1 or X2 Clock Input measured a digital float or approx. 1.5 - 2.0 volts steady DC level.
These X1 and X2 are taken directly from a Ceramic Oscillator (Crystal ) with parallel small capacitors.
I had always thought their was supposed to be a Sinewave measured on both pins of the Ceramic or Crystal Oscillator component.
Anyway, the unit is operating fine ! As Is.
Just ran across this being curious.
Any suggestions . . .
AlbertHall
Joined Jun 4, 2014
12,663
The capacitance of the probe can be enough to stop the oscillator when connected to the input of the oscillator circuit which I think is what happened when you saw the DC level. A X10 probe may give better results but it will still disrupt the oscillator to some extent.
cferry77
Joined Jun 9, 2018
6
Hello Again -
I Oscoped these X1, X2 signals on another unit and both signals appeared as what I am used to seeing on uP Crystal Oscillator Input Pins.
Both signals were a slightly distorted Sinewave at exact 4.20 MHz with a slight positive (maybe .25 volt) DC offset from ground.
I believe that the first unit which started this thread _ I later found that possibly the weird signal levels were due to the Scope Probe, Scope Probe Ground or that Probe or Oscope was set on the X10 scale.
