unipolar dac to bipolar dac output,query in simulation
ak52
Joined Oct 15, 2014
241
Hello Everyone,
My DAC inside the microcontroller is a unipolar dac and can only work from 0 to 3.3v.Using a differential amplifier with an offset i was able to scale it upto +10v to -10v.
The simulation is attached.
In the circuit, when i change R8 and R9 to 10k,my output reduces by one volt,can someone please explain why this is happening?
Many thanks,
AK
ericgibbs
Joined Jan 29, 2010
21,466
hi ak,
The gain of the OPA is no longer *2.
Its approx 20k/15k the two 10ks are effectively in parallel and in series with the existing R1, 10k
E
Consider reducing R1 to 5K.
ak52
Joined Oct 15, 2014
241
Ah i see it now,i actually dont want to use the voltage divider there it saves me two resistors,do you know a better way of generating 1.65v reference??
ericgibbs
Joined Jan 29, 2010
21,466
hi,
You could use a single OPA, dedicated to creating a 1.65Vref, use the output for R1 and R12 , Vref source
The Vref source must have a low impedance if you are sharing it with different OPA inputs.
E
ak52
Joined Oct 15, 2014
241
yeah but TL084 comes with 4 opamps inside,anyway the 20k resistors is much better thanks for that :)
AK
Kjeldgaard
Joined Apr 7, 2016
476
I have a simpler circuit:
The selected resistor values should be within 0.5% of the nominal.
Bias resistor R4 can perhaps be omitted.
And if you want other resistance values, the ratios are:
  • R1: 1.00
  • R2: 0.67
  • R3: 2.03
  • R4: 0.33
