Unidentified SMPS
sagor
Joined Mar 10, 2019
1,055
Is it a SMPS? Looks more like a linear supply. Check all the capacitor voltages, if they are all low (less than 100V), then most likely it is a multi-voltage linear supply, with perhaps some overcurrent and overvoltage protection on each voltage level supplied..
A SMPS would likely have some high voltage capacitors on a primary side, directly fed from diodes connected to the AC input voltage.
Ian0
Joined Aug 7, 2020
13,279
There's a sizable C-core transformer in there, and along with the capacitors would suggest a linear power supply.
There's also a RM pot-core, which suggests that the output of the linear supply might be stepped up or down to a different voltage with a switched mode.
irobbie
Joined Apr 29, 2025
12
Yes I’ll check, it uses 3 tda 1060 control ice , also some d45c’s , also split supply-via 2 lots of 4diodes thank you oh and capacitors all under 100v
Pyrex
Joined Feb 16, 2022
554
The photos do not show large heatsinks, like those found in linear regulators.
The TDA1060 microchip is an SMPS controller. The ferrite choke with the yellow coil is probably visible in the photo above.
irobbie
Joined Apr 29, 2025
12
There are three small heatsinks each have a D45c and a byw29-150 thanks, also there are three of those chokes,,
