understanding the logic of timer delay in STM32F407
yef smith
Joined Aug 2, 2020
1,481
Hello,My APB1 bus frequency is 21Mhz as shown in the clock diagram bellow.
I have the following code for timer delay shown in the photo bellow.
I have PSC register and ARR register to define the TIMER.
In timer we are counting up every clock tick up and ARR is the value where we are reseting the counting.
from the RM link shown bellow,We have other registers like CCR1,DIER,EGR.
I am trying to understand the logics of this registers.
I Cant find in the CR register the counter overflow interrupt option.
Where is it?
Thanks.
https://www.st.com/resource/en/refe...-arm-based-32-bit-mcus-stmicroelectronics.pdf
35,181
There are two types of polling algorithms, (1) blocking and (2) non-blocking.
(1) blocking functions will wait until a given event has occurred before moving on with code execution.
Usually, delay( ) functions are blocking because the purpose of the delay( ) function is to suspend code execution for a given length of time.
(2) non-blocking functions are useful when you want to continue with code execution while waiting for a given event. Non-blocking can be implemented with or without interrupts.
Test that the TIM4 module is working without interrupts. You can use the debugger and observe that CNT register is being altered.
PSC = 0 and ARR = 0xFFFF should cause the UIF bit in SR to go to 1 every 780μs (with 84MHz clock).
In software you can test UIF bit in TIM4->SR and reset it when it goes to 1. Toggle a GPIO pin when this happens.
There is no CR register, only CR1 and CR2.
The status and interrupt flags are in SR.
yef smith
Joined Aug 2, 2020
1,481
Hello MrChips,SYSCLK shown bellow is 168MHz
and there is an interrupt called systick handler.
So this kind on handler will be call every 1/(168000000) seconds?
in the manual for some reason they say that systick handler is called every 1miliseccond.
They say its because of
SYSTICK_CONFIG(SytemCoreClock/1000);
which makes the systick a 1 milli second.
i cant see how its happening.
Thanks.
35,181
SYSCLK is 168MHz. This is the clock speed of the MCU. The interrupt speed is not related to this (except for interrupt latency).
The SYSTICK timer is part of the ARM core, called Cortex System timer. It would be best to leave this alone.
For what you are doing you need to focus on the clock source of TIM4.
yef smith
Joined Aug 2, 2020
1,481
Hello MrChips I have written the following code for microsecond delay ,i just use delay(1000) to have 1milisecond delay.
I cant see the dinammic of the the delay.
my APB1 clock is 21Mhz ,ARR=21 makes the counter to overflow every 1MHz and call the TIM4_IRQHandler function which will increase myticks by 1.
but how in parralel the delay function will check if myticks<us, as i see it ,we will be stuck on the delay "while"
how in paralel the TIM4_IRQHandler will run timer overflow?
Thanks.
Code:
   void delay(int us)
        TIM4->CR1|=TIM_CR1_CEN;
        myticks=0;
        while(myticks<us);
        TIM4->CR1&=~TIM_CR1_CEN;
void TIM4_IRQHandler(void)
    myticks++;
  TIM4->SR&=~TIM_SR_UIF;
int main(void)
    RCC->APB1ENR|=RCC_APB1ENR_TIM4EN;
    TIM4->PSC=0;
    TIM4->ARR=21;
    TIM4->CR1|=TIM_CR1_URS;
    TIM4->DIER|=TIM_DIER_UIE;
    TIM4->EGR=TIM_EGR_UG;
    NVIC_EnableIRQ(TIM4_IRQn);
35,181
myticks gets incremented once every 1μs.
while(myticks<us);
will eventually be FALSE.
I would change the declaration
void delay(int us) to
void delay(unsigned long us)
and declare myticks globally as unsigned long also.
yef smith
Joined Aug 2, 2020
1,481
HellO MrChips.At first i used HAL_DELAY to control my DAC,and i got the following shape on my scope as shown bellow.
I have updated the code as you said,i get a total noise on my scope.
where did i go wrong?
Thanks.
Code:
#include "main.h"
/* Private variables ---------------------------------------------------------*/
DAC_HandleTypeDef hdac;
unsigned long myticks;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_DAC_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
        myticks=0;
        while(myticks<us);
    myticks++;
int main(void)
    TIM4->PSC=0;
    TIM4->ARR=21;
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_DAC_Init();
  /* USER CODE BEGIN 2 */
HAL_DAC_Start(&hdac,DAC_CHANNEL_1);
HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,1365);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
       HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,0x00000000);
           //HAL_Delay(2);
        delay(20000);
           HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,0x00000400);
           //HAL_Delay(2);
        delay(20000);
           HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,0x00000800);
           //HAL_Delay(2);
        delay(20000);
           HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,0x00000C00);
           //HAL_Delay(2);
        delay(20000);
           HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_12B_R,0x00000FFF);
           //HAL_Delay(2);
        delay(20000);
           //HAL_Delay(2);
        delay(20000);
           //HAL_Delay(2);
             delay(20000);
           //HAL_Delay(2);
             delay(20000);
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 4;
  RCC_OscInitStruct.PLL.PLLN = 168;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV8;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
  * @brief DAC Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN DAC_Init 0 */
  /* USER CODE END DAC_Init 0 */
  DAC_ChannelConfTypeDef sConfig = {0};
  /* USER CODE BEGIN DAC_Init 1 */
  /* USER CODE END DAC_Init 1 */
  /** DAC Initialization
  hdac.Instance = DAC;
  if (HAL_DAC_Init(&hdac) != HAL_OK)
    Error_Handler();
  /** DAC channel OUT1 config
  sConfig.DAC_Trigger = DAC_TRIGGER_NONE;
  sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_ENABLE;
  if (HAL_DAC_ConfigChannel(&hdac, &sConfig, DAC_CHANNEL_1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN DAC_Init 2 */
  /* USER CODE END DAC_Init 2 */
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15, GPIO_PIN_RESET);
  /*Configure GPIO pin : PA0 */
  GPIO_InitStruct.Pin = GPIO_PIN_0;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /*Configure GPIO pins : PD12 PD13 PD14 PD15 */
  GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
35,181
Put a breakpoint in the TIM4_IRQHandler( ) to confirm that it is being called.
If you have an oscilloscope, toggle a GPIO pin in TIMR_IRQHandler( ) and measure the interrupt period.
yef smith
Joined Aug 2, 2020
1,481
Hello MrChips,i added the toggle line and my HOME scope gave me a result as shon bellow.
Its not very accurate,but we see 1Mhz clock signal.
So the Irqhandler works great.
in the delay finction Myticks increasing evey 1microsecond is comparing myticks to us value in a while loop.
I tried to call delay(500000) and put the toggle before and after the loop to see if my led is blinking every half a second.
it didnt blink every half a second it stayed ON ,So for some reason it got stuck in the while loop .
The full code is shown bellow.
Where did i go wrong?
Thanks.
Code:
        HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_12);
        while(myticks<us);
        myticks=0; //reset my ticks after
Code:
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * <h2><center>&copy; Copyright (c) 2021 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under BSD 3-Clause license,
  * the "License"; You may not use this file except in compliance with the
  * License. You may obtain a copy of the License at:
  *                        opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
  * @retval int
        HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_13);
        while(myticks<us);
    myticks++;
    //HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_12);
int main(void)
    TIM4->PSC=0;
    TIM4->ARR=21;
  HAL_Init();
  MX_GPIO_Init();
  MX_DAC_Init();
  /* Infinite loop */
  while (1)
        delay(500000);
           HAL_Delay(2);
 //     delay(10000);
           HAL_Delay(2);
    //     delay(10000);
           HAL_Delay(2);
    //    delay(10000);
           HAL_Delay(2);
    //     delay(10000);
           HAL_Delay(2);
        // delay(10000);
           HAL_Delay(2);
         //delay(10000);
           HAL_Delay(2);
        //     delay(10000);
           HAL_Delay(2);
            // delay(10000);
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
    Error_Handler();
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
35,181
Forget the delay( ) and HAL_Delay( ) functions for now.
Modify
TIM4->ARR=21;
with higher values and watch the TIM4_IRQHandler( ) toggle output until you get consistent periods >10μs.
Make sure that you remove in every place especially in delay( ) except in TIM4_IRQHandler( ).
yef smith
Joined Aug 2, 2020
1,481
Hello Mr.Chips, with PSC=0 and ARR=210 i got 10us period as shown in the scope photo bellow.
Its still gets stuck on the while loop,I tried to toggle LED with DELAY(500000) and i didnt see any togling.
i put the LED toggling inside "delay" as a comment later.
The full code updated is shown bellow.
What could be done?
Thanks.
Code:
  * @file           : main.c
  * @attention
#include "main.h"
  * @retval int
        //HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_13);
        while(myticks<us);
    myticks++;
int main(void)
    TIM4->PSC=0;
    TIM4->ARR=420;
  HAL_Init();
  MX_GPIO_Init();
  MX_DAC_Init();
  /* Infinite loop */
  while (1)
        delay(500000);
           HAL_Delay(2);
 //     delay(10000);
           HAL_Delay(2);
    //     delay(10000);
           HAL_Delay(2);
    //    delay(10000);
           HAL_Delay(2);
    //     delay(10000);
           HAL_Delay(2);
        // delay(10000);
           HAL_Delay(2);
         //delay(10000);
           HAL_Delay(2);
        //     delay(10000);
           HAL_Delay(2);
            // delay(10000);
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
35,181
Your output is not toggling properly. If it were toggling properly you would see a square wave (50% duty cycle).
Remove all the code in the while loop:
while (1)
After you get this working correctly I will show you a better way to output to the DAC.
yef smith
Joined Aug 2, 2020
1,481
Hello Mr.chips, I have emptied the while loop as shown in the code bellow it didnt change the shape,and stayed as before.
I think ARR=420 means counting till 420 and then toggling when it overflows the counting.
I tried to put ARR=1 and PSC=210 as shown bellow so it will do overfloows on every clock cycle but it didnt work and i got the same result.
Why its not giving me 50% duty cycle?
Thanks.
Code:
  * @file           : main.c
  * @attention
#include "main.h"
  * @retval int
        while(myticks<us);
    myticks++;
int main(void)
    TIM4->PSC=210;
    TIM4->ARR=1;
  HAL_Init();
  MX_GPIO_Init();
  MX_DAC_Init();
    delay(500000);
  /* Infinite loop */
  while (1)
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
35,181
Either you are using the wrong count mode, or the wrong interrupt bit.
For now, clear TIM4->SR = 0;
I will look at your mode and code later.
yef smith
Joined Aug 2, 2020
1,481
Hello Mr.chips TIM4->SR=0 will erase State register in every bit.
I added this line in the updated code bellow. it didnt change the shape ,i still get 10us period but 96% duty cycle.
the closest case i got to 50% duty cycle is ARR=1 and SCL=21 and only the i get a plot as shown bellow.
Code:
  * @file           : main.c
  * @attention
#include "main.h"
  * @retval int
        while(myticks<us);
    myticks++;
int main(void)
    TIM4->PSC=210;
    TIM4->ARR=1;
    TIM4->SR=0;
  HAL_Init();
  MX_GPIO_Init();
  MX_DAC_Init();
    delay(500000);
  /* Infinite loop */
  while (1)
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
35,181
Do one thing at a time.
Set up
PSC = 0
ARR = 1000
empty the while loop
while (1)
Post the waveform and show all of your code.
yef smith
Joined Aug 2, 2020
1,481
Hello Mr Chips,I have done as you said the irq toggling is as shown bellow.
Why i get stuck in the while loop in the delay function?
Thanks.
Code:
  * @file           : main.c
  * @attention
#include "main.h"
  * @retval int
        while(myticks<us);
    myticks++;
int main(void)
    TIM4->PSC=0;
    TIM4->ARR=1000;
    TIM4->SR=0;
  HAL_Init();
  MX_GPIO_Init();
  MX_DAC_Init();
  /* Infinite loop */
        delay(50);
  while (1)
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
yef smith
Joined Aug 2, 2020
1,481
Hello MrChips,When i removed the while line in the wait function i got some noise with 30mV pk-pk.
Thanks.
Code:
  * @file           : main.c
  * @attention
#include "main.h"
  * @retval int
    myticks++;
int main(void)
    TIM4->PSC=0;
    TIM4->ARR=1000;
    TIM4->SR=0;
  HAL_Init();
  MX_GPIO_Init();
  MX_DAC_Init();
  /* Infinite loop */
        delay(50);
  while (1)
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
