Understanding ohms law
Miracletech
Joined Nov 15, 2019
160
In school, we were performing tests where you connect a resistor in parallel with a DC voltage source.
In my case, I am using a 3v DC source and a 2A current source, with a 1k ohm resistance. Is there any way of calculating the voltage and current output from the circuit without a millimeter, and what is this type of circuit called?
SamR
Joined Mar 19, 2019
5,534
Simply apply Ohm's law. Current = Voltage/Resistance. You set the V on the power supply, used a resistor marked with it's value R so calculate the I. And it's not in Parallel, it's in series.
dl324
Joined Mar 30, 2015
18,453
I don't see a 2A current source.
I assume "millimeter" means multimeter.
There is no special name for the circuit. You're extremely limited without a meter. Voltage sources and resistors have a tolerance, so you need to take measurements to calculate actual current.
SamR
Joined Mar 19, 2019
5,534
The confusion may be the "2A Source". It may be capable of providing up to 2A but will only provide the current needed by the circuit.
Miracletech
Joined Nov 15, 2019
160
We used a 3v battery (1.5v*2), I measured current from battery using multimeter, it's reading 2.40, I don't know the difference between AH and Amps......
bertus
Joined Apr 5, 2008
22,994
How did you measure the current?
Current measurements are done in series with the load.
Voltage measurements are done accross the load.
Bertus
SamR
Joined Mar 19, 2019
5,534
Amps have to be measured by inserting the multimeter into the circuit. The circuit has to be opened and the meter made part of the circuit. I will need to be on the mA (milliamp) range of the meter. If you used the meter across the battery you are shorting out the battery and may in fact measure 2+A briefly.
peterdeco
Joined Oct 8, 2019
484
There is no voltage to calculate. It is 3V. Regardless of how many amps your power supply can provide, the current flowing through the resistor is determined by it's resistance. Your schematic already shows 3mA as the current. This picture is called an Ohm's Law Triangle. It's an easy way to remember V=IxR, I=V/R, R=V/I. In your case I=3/1000 = .003 = 3mA as you show. Working backwards, let's say you don't know the applied voltage but know you have 1K with 3mA running through it. Then it's V=.003x1000 = 3.
Miracletech
Joined Nov 15, 2019
160
Where I am confused is the fact that:
When we tested voltage from the circuit in class, the voltage reduced, and also the current too.
Miracletech
Joined Nov 15, 2019
160
We are to solder two wires to each terminal of the resistor; one for DC input and the other for DC and current output
peterdeco
Joined Oct 8, 2019
484
"In my case, I am using a 3v DC source and a 2A current source, with a 1k ohm resistance."
Something's very wrong. A 1K resistor will not load down a 2A current source.
BobaMosfet
Joined Jul 1, 2009
2,211
Amazon & Google are fantastic sources for educational materials on basic electronics. This is well worth the purchase:
Title: Understanding Basic Electronics, 1st Ed.
Publisher: The American Radio Relay League
ISBN: 0-87259-398-3
dl324
Joined Mar 30, 2015
18,453
You need to consider the effect of inserting a meter into a circuit to measure current (or voltage). All DVMs will introduce a resistance when measuring current. The magnitude of the effect will depend on the meter and the current range.
A better approach is to measure the voltage drop across the resistor and calculate current using Ohm's Law.
As you've observed, 2 1.5V batteries in series don't necessarily give 3.0V. When fresh, the nominal voltage will be higher than 1.5V per cell. Under sufficient load, battery voltage will drop.
SamR
Joined Mar 19, 2019
5,534
When measuring mA's the multimeter's impedance is significant. Even using the marked resistance of a resistor and ignoring the precision it will be more accurate to calculate the current than to measure it due to the meter's impedance.
