Yes and no.Is my apartment's floor and walls considered "ground"?
Not really, no, when it comes to any useful behavior you would expect from a "ground". You could not put a lightbulb between "hot" and your floor and expect it to light up. Not enough current could flow. If you had a big enough sheet of metal to lay on a wet floor and wired it to your bulb, maybe.
Yes, when it comes to shocks and personal safety. It takes much less current to produce a painful or even dangerous shock than to light a bulb. Bare feet on linoleum tile, or probably just about any flooring, is plenty adequate grounding to produce an unpleasant shock.
