Post #137 gave the inductor calculation for an inverting buck-boost converter, and that is not what you have. I'm not even sure what this would actually be called.I chose values gleaned from previous posts:
Supply voltage input:
Vin min=24
Vin nominal= 27
Vin max=30
Required output voltage:
Vout max=30
Vout nominal=17.5
Vout min=5
Required output current:
Iout max=5A
See below (new values circled in green, modified parts circled in red)
its a non-inverting septic converterPost #137 gave the inductor calculation for an inverting buck-boost converter, and that is not what you have. I'm not even sure what this would actually be called.
It's SEPIC (Single Ended Primary Inductance Converter)its a non-inverting septic converter
Trying to work with the inductors the TS has on hand (hand-made, 30uh x 2).It's SEPIC (Single Ended Primary Inductance Converter)
Apparently, the usual design assumption for a SEPIC converter is that both the inductors and capacitors are large. e.g. 100μH and 100μF
Simulation shows a typical open loop circuit.
As the duty cycle goes over 50% the control of the output voltage gets very coarse and sensitive making precise closed loop control increasingly difficult. Notice also the increase in current and voltage ripple at high duty cycles. There are also losses to account for in the switching time and the diode.
Thank you for your explanationIt is not possible to build or test your design if you don't have a design specification to work from.
It indicates you have no idea what you are building. So how can anyone help if you don't know what your building?
You should remember that in any DC-DC conversion scheme the one immutable rule. The power out will always be less than the power in. In some cases, it will be much less. Your stated goal may not be achievable in practice. For example, 27V @ 15 A = 405 watts of input power. Assume the conversion is 85% efficient (just to be charitable), and the output voltage is 26 VDC; then 405 watts /26 VDC = 13.24 A. In short, I don't think your chances of success look very promising. Lacking the ability to articulate achievable results you should probably get used to disappointment.Thank you for your explanation
I know exactly what I want
I just don't understand your terms.
The input of my circuit is 27 volts and 15 amps.
I don't know how to tell you Vin max or Vin min
I expect the circuit to give me at least 15 amps when the output voltage is equal to or less than the input voltage.
But I don't need more than 8 amps in output higher than 27 volts.
Ok, thank you very muchAlso worth noting:
1) The output is discontinuous, so for 15A output, there will be pulses of at least 30A through the diode, maybe up to 60A if the inductance is small.
2) the current through the MOSFET is input current + output current =45A
3) the voltage across the MOSFET is input voltage + output voltage,
so at least 60V
According to the MOSFET datasheet, it supports this much.2) the current through the MOSFET is input current + output current =45A
so at least 60V
We have two different things to work with on the table. The original design with the IC controller chip and the fundamental SEPIC circuit detailed in post #144. We can outline possible outcomes very quickly by simulating various combinations of input voltage, and duty cycle which will yield various results in terms of output voltage, ripple current and ripple voltage. We know from the formulas in post #146 that things we do not want (current and voltage ripple) are linear functions of duty cycle. We can automate the data collection and display of this data so you can get an idea of what is possible.Ok, thank you very much
This was a very good tip.
I don't want to make the impossible possible.
I want the best real values
I was able to improve the voltage drop by changing the value of some parts.
Also, the heating of the MOSFET is slightly reduced.
Can I ask for 25V 10A from this circuit?
Can I ask for example 40V 5A?
Guys, I may not be able to say what I mean well with little information, but I would like some guidance to get the maximum "real" power available from this circuit.
Thanks
The instantaneous power dissipated in a MOSFET is the instantaneous drain current, Ids, times the instantaneous drain to source voltage, Vds, integrated over a single switching period. That is:one question:
How is "power dissipation" calculated in MOSFET?
To be pedantic we're both wrong as we have both given the energy not the power.The instantaneous power dissipated in a MOSFET is the instantaneous drain current, Ids, times the instantaneous drain to source voltage, Vds, integrated over a single switching period. That is:
\[ P_{D}\;=\;\int_{0}^{T}I_{DS}(t)V_{DS}(t)dt \]
where T is the period of the switching frequency.
thank you for your guidanceMaybe your inductor connection is not correct. Make sure Drain connected to winding toward v+ and anode to winding toward gnd.
