Hi guys what does it mean by Typical CTR value of Optocoupler.
Thread Starter khatus Joined Jul 2, 2018 115 Aug 8, 2020 #1 Hi guys what does it mean by Typical CTR value of Optocoupler. Last edited by a moderator: Aug 8, 2020
P peterdeco Joined Oct 8, 2019 484 Aug 8, 2020 #2 CTR is the Current Transfer Ratio. It is dependent on current gain of the transistor, supply voltage, etc.
ericgibbs Joined Jan 29, 2010 21,567 Aug 8, 2020 #3 hi k, Due to manufacturing tolerances of the Opto, the spread in CTR can range from 30% to 90%, a typical value of 60% is the mid range of the spread. E
crutschow Joined Mar 14, 2008 38,767 Aug 8, 2020 #4 So, for a proper design, you use the min and max values, not the typical values. Last edited: Aug 8, 2020
