Type of equipment
atferrari
Joined Jan 6, 2004
5,032
this is the link from where I made the device but in this video he is using computer adapter which iam using right now but the magnetic field is week and I want to strengthen the field by raising the power
A long video.
I was genuinely interested in knowing what your intention is but 1h 10m...no, not for me.
Ya’akov
Joined Jan 27, 2019
10,368
I‘m sorry to say this “device” is utter nonsense and could be dangerous. The fact that you intend to but it in a bath with you means there is a non-zero chance you will be electrocuted.
The way this is built is absurd, it can‘t do anything useful and the “proof“ using the compass is silly. Not only is there nothing important about an electromagnet that turns on and off, the compass shows the field is incredibly weak. Any one of those not very strong ceramic magnets could easily pin that compass violently while the coil is only making it deviate slightly.
The claim that the triangular geometry makes it more powerful is also nonsense.
The entire basis of this concerning “programs” in nanoparticles that are ”erased” by this useless device is absurd. All of this charlatan‘s patter is bullshit—full stop.
The biggest problem, though, is the danger presented by using an electrical device in the bath. Increasing the power to the coil makes this worse. So we won’t be “helping‘ you with this, except to the extent we will not tell you how to increase the danger.
LowQCab
Joined Nov 6, 2012
5,102
This YouTube Channel is nothing but garbage-Click-Bait.
( Much stronger words are definitely called for here )
You are wasting your time watching this site.
Do not live in "fear".
The more hard and legitimate research that You do, the less fear You will have.
Unfortunately, the Internet is literally over-flowing with hot-steaming piles of crap.
KeithWalker
Joined Jul 10, 2017
3,628
I don't have an hour to waste watching a youtube video. What are the details of the device he recommends to power it?
djsfantasi
Joined Apr 11, 2010
9,237
I only watched 1 minute and 26 seconds. His posters referring to chemtrails and toxic aerosols was enough for me. This topic is a well known false conspiracy theory that has no bearing in reality. That plus the dubious title of “Anti-Nano Triangle” immediately left me with the impression that the likelihood that the video was 100% bullpuckey was approaching unity. The only thing this project was good for is an entry for the Darwin Award for Assisted Suicide.
LesJones
Joined Jan 8, 2017
4,544
I skimed through the video mostly on fast forward to see if it gave any idea of the reasoning behind the device.
One interesting thing was that details of the power supply was shown. It was a laptop power supply which are normaly about 19 volts at 3.5 amps (60 Watts.) One amusing point was the power LED on the power supply was flashing on and off. I think this was an indication that the power supply was sutting down due to overcurrent and then attempting to restart. I agree with the last three posts that the whole video was total rubbish.
So if the OP wants to continue wasting time and money I have pointed out the information about the power supply that is recommended.
Les.
28,593
From the very first post there was the first ambiguity: "Speaker wire", for normal applications means a pair of conductors, insulated from each other but not to standards suitable for mains voltages . Then, "Connect to electricity" is an even less clear term.
But after reading the comments about the you tube video it becomes totally clear that, (to use polite terms), the presentation is a work of fiction, being no closer to reality than "Road Runner and Coyote" cartoons. This is the reason I call YT the Cartoon Channel". Works of total fiction presented as alternative science.
Ya’akov
Joined Jan 27, 2019
10,368
For those who couldn’t wade through the video here are the key points:
  • The “device” is supposedly a way to ”erase the programs” from nanoparticles via a specially constructed magnetic field. It is intended to be used in the bath—yes, submerged.
  • Nanoparticles are responsible for every physical and mental complaint you have, and they are unavoidable—you are packed to the gills with them even as you read this.
  • Things are worse now because 5G cell sites “activate” these nanoparticles.
  • Something about biofilms and how nasty they are—though I couldn’t work out the connection in the time I was willing to invest.
  • The device is constructed on a triangular frame, using inverted duct tape to hold the components in place during assembly and it is removed from the frame afterwards.
  • The specifications for the number, size, and specific type of components is left to the constructor. ”You can use whatever you want” is a constant refrain. Despite the apparent criticality of the triangular geometry, which was empirically determined (but apparently stand by for the pyramid, currently under investigation) the most important determinant of the components and their assembly is “what you want to do”.
  • The video maker uses a series or ~25mm round ceramic magnets. He uses 6 per side as three rows of two. The magnets are placed on the duct tape which has been secured, adhesive side out, to the triangular frame (made of three cutting boards, hot glued together). The polarity of the magnets “doesn’t matter” so long as you make sure the next layer has a matching magnet on top where the poles are reversed (the magnets repel). The exact position of the magnets doesn’t matter.
    The next layer is a repeat of the first but with the polarities reversed. One more layer follows, for a total of three.
  • Next comes the wire which can be… whatever you want. But he’s using 14AWG vinyl insulated zip cord split in two—because it is cheap. Apparently, booze and copper are very dear in Canada and so cheap is important. I can’t recall the precise length of the wire involved but it made fewer tjhan 20 turns around the frame.
  • Next is the power supply—a 19V laptop brick. It is connected directly to the coil. The power supply “pulses”, which is very important. It achieves this by overloading because the coil is a low resistance piece of wire, then shutting down. It starts up again in ~20ms and keeps doing this. It seems unlikely that will be a recipe for long life but, who knows?
    To make the “pulsing“ stronger you can attach an auto flasher module. It makes things better… somehow. An alternative to the auto flasher is a “relay” but be careful because “if you use the relay you‘ll have to use a resistor to keep it from burning out; just wire it up like you usually would [in such cases]. Unfortunately, I must admit my ignorance of the usual way to wire a relay to a triangular coil for… doing that thing.
  • To prove that the device works and show how amazingly powerful it is, the creator uses a magnetic compass. For some reason it is still in its blister packaging so if you are going to try to reproduce this be sure to have an unopened orienteering compass to test it. The compass is placed a few millimeters from the coil, and it is turned on. Sure enough the compass deflects at least a couple of millimeters each time the coil receives power.
    The deflection is perpendicular to the normal plane of the compass, so apparently, the compass was built wrong at the factory.
  • Also, you should use calcium and… oh my, I’ve forgotten all the random metals and minerals he suggests as supplements to neutralize the nanoparticles and biofilms. I guess I‘m not going to make it.
KeithWalker
Joined Jul 10, 2017
3,628
Thanks, Ya'akov for taking the time to review it. I didn't have the time to do it myself. In the light of such confounding youtube wizardry, my expertise pales. I am not able to add anything more of value to the TS's project except to advise him to wear rubber boots and waterwings in the bathtub and to have several PC power supplies and a resuscitator available when he tries it out.
sam717
Joined Nov 29, 2023
10
Thanks for your reply and because you understand what iam trying to do I have already been using the device for a month in the water without any problem and I added the flasher and the magnetic pulser become stronger but now I want to make even stronger so if you have the expertise please help and thanks again for going through the whole thing before starting to making judgment
Ya’akov
Joined Jan 27, 2019
10,368
First, I am compelled to start by saying—if you are suffering, and you feel this device has brought you some relief, I am glad for that. I am loathe to take away something that gives you relief or hope but I sense that it is being taken away by reality at this point.
It is a non-completely-blind surmise when I say that if you have felt relief it is the result of the placebo effect and not of anything to do with the power of that dangerous contraption. Placebo effect is real and the relief people can get because of it is equally real. But it won’t necessarily keep working because it has to do with the beliefs of the person experiencing it.
That you want to “increase the power“ says to me it isn’t doing it for you like it did at first. But to ”increase power”, you have to have “power“ to begin with.
I understand the claims your YouTuber is making, but I also reject the claims because my knowledge and experience tell me that it is nothing more than a jumble of ideas glued together with bald assertions. In other words, it’s a con and he is a con man.
The entire thing is based on several unproven—and very easily disproven—assumptions. Principal among these is that there are ‘programmed nanoparticles” that need to “erased” in order to alleviate an entire constellation of symptoms that are well known to be tied to diet, sleep, and exercise.
Just looking at the guy you can see he’s unhealthy, and it is no surprise to me he suffers from those things and more. His concern with alcohol prices suggests he’s a least a regular drinker if not more. Plenty of studies have show the negative impact of more than minimal alcohol consumption.
Before risking electrocution, I‘d look into a plant-based diet which, unlike programmed nanoparticles activated by 5G cell sites, has a great deal of rigorous science to back it up. (and I am not being dramatic, electrocution is a real possibility each time you get into a tub of water with that silly thing.)
50V is generally considered the highest intrinsically safe voltage for humans. The 19V of the power supply he is using is below that. But 19V is not the only voltage that might be present at the output of the supply. Many of those supplies are referenced to the mains voltage—this means depending on where you plug it in, there could be anywhere from 100-240V AC, in addition to 19V DC.
There have been instances of fatal electrocution from 5V phone chargers for this same reason, and in bath tubs for that matter. There is a chance that the only reason you aren’t dead is because water has not yet found a way in back the duct tape to connect you to the power supply’s leads. Duct tape is not waterproof and in this case it is a critical safety element.
So, unfortunately, the way I can help you isn’t to make the contraption more ”powerful”, rather it is to try to help you make your critical thinking more powerful so you can see through the con you are currently caught up in. Ask yourself:
What proof is there of “programmed nanoparticles”?
If there are such things, how is this device supposed to erase them?
Why are there both permanent magnets and an electromagnet, how is that better?
Why should you accept an explanation about the source of your suffering that is so tortured, and relies on so much hidden, secret, and confusing information when simpler, well documented alternatives exist?
Why haven‘t you contacted this YouTuber for help? If you actually believe I have expertise, please consider what I have said. And remember, “power” is a measure of the ability to do work, and work means affecting a change in the environment. Since this device doesn’t do anything useful, there is no way to make it more “powerful”.
You are assuming providing it with more electrical power is the same as making it “more powerful” but it is just going to make it hotter and it has to dissipate more current. It will make it no more effective that it currently is, and the fading effect you are experiencing will not be reversed no matter how much power you try to add.
Although I had very strong suspicions from the outset, rejecting it without knowing what was being suggested and claimed I would have been as bad as your charlatan guru. I really do want to help you but I can‘t do it using this device.
The plant-centered diet suggestion was a real one. If you research that term, and follow the advice, in as little as 2 weeks you could be feeling like a new person. Seriously. It is very fast to reverse the troubles caused by the SAD (Standard American Diet) which is now really the SWD (Standard Western Diet) insofar as just about any first world country is going to be going down the same path.
Best of luck, I hope you find your solution. Be well.
28,593
Clearly the triangular shape is to utilize some "pirimed power. And I offer a question as to who programmed those nano-particles, and what sort of system was used.
What is common in recognized science is to not only publish ones discoveries, but then to also publish sufficient information so that others can duplicate the process and the results, thus verifying the claimed discoverer's right to fame and glory.
This process is quite demanding in that the explanations must be presented in terms that those qualified can understand. INdeed, that is a brutal requirement, no argument about that. But it is also a GREAT WAY TO DISCOVER ERRORS. And publishing claims of a discovery later shown to be invalid is certainly a source of great embarrasment in the scientific community.
