Have an irrigation control which selectively opens one or two solenoid valves to water two areas. Pressure to the system is via a solar pump. Rather than run the pump continuously I would like to have it turn on when the solenoid valves open and off when they close.The pump controller has an input if open circuit pump runs, closed pump stops.NOTE: Only power available is fro irrigation control 12v DC or solar panels 48v DC.
My idea was to use the current flowing to the solenoid valve to activate a NC relay. When solenoid activates contacts open. The pump control senses open circuit and starts running. Solenoid valve off, relay closes and pump turns off. Fine for one solenoid valve .
Nest step was to fit a second relay parallel to the first. Each activated when a different solenoid valve is powered but sharing a single output connection.
What I forgot was that if only one circuit is active then the other will be in the NC state. The output will be closed circuit and the pump will not run.
Is there some way of using a single relay for this job? Dual coil relay?
