I have a Vizio E500l-B1 with a Power board ADTV3613XA6
The problem is I have no power, no lights on in front.
What I've checked
120 V out of the outlet
120V coming into the circuitboard
But when I check the voltage at the fuse I get almost nothing, but if I remove the fuse and check each end of the fuse holder the voltage is 120v
With the power plugged in and on the DC side I have the following
With everything plugged in
Pic 1
5.15v
Empty
12.3v
15.5v should be 24v
Ps_on 2.95v
Pic 2
15 volts on each 1234 pins should be 24v
Not sure where to go from here.
Any help would be appreciated thank you
What I've checked
Pic 1
5.15v
Empty
12.3v
15.5v should be 24v
Ps_on 2.95v
Pic 2
