Turning power supply of OpAmp off.
killerpiraat
Joined Feb 17, 2020
18
I was wondering, is it possible to switch the power supply of an opamp on and off via a switch or output of a microcontroller? For example to save batterylife.
I heard something about latch up symptoms that occur when you apply a input signal when the power supply is turned off? Does this damage the opamp?
MrSoftware
Joined Oct 29, 2013
2,273
First what exactly do you want to do (do you have a schematic)? Second the datasheet for the OpAmps you are considering should tell you what their behavior is when power is removed.
