- Joined Jan 23, 2018
- 28,312
If the motor has brushes then itis a universal motor and it will run on DC and AC. THAT is why it is called a UNIVERSAL motor. It will run better on DC and put out a bit more power. And it will run quite well on 18 volts DC.
IN a blow-dryer application the motor is cooled by the air stream passing over it and so if you are running it as a cool air blower that should work quite well, if you still have the air flowing over the motor.
BUT if you change the blower so that the motor is directly powered from a DC supply you will need to change the plug-in end of the cord so that it does not get connected directly to the mains, since that will not work correctly after the change.
