Turn on LED's after a specific voltage level
eetech00
Joined Jun 8, 2013
4,724
Hi.
I have a circuit with 3 voltage levels: +40V, +8V and +5V. I want to detect if these voltage levels are present using 3 LED's.
My idea is that when the voltage levels are below 10% of the required levels, so +36V, +7.2V and +4.5V respectively, I want the LED's to turn on. When the voltage levels are above, they turn off.
Any idea how to do this, maybe using comparators?
how much detection accuracy to you need? For example, what if the 7.2 led turns on at 7.1?
what is the supply voltage for the detector circuits?
Riddersholm
Joined Jun 1, 2019
9
I think this will work (based on DodgyDave suggestion).
The LEDs turn on when the voltage is low and eventually turn off if the battery continues to drain.
The LEDs are set for 5mA.
Thank you so much, eetech00, your curcuits suits my needs perfectly.
One last question though: How do you determine the resistor values, i.e. what are the formulas? :)
38,767
The TL431 changes state from conducting, when the sense voltage is above 2.5V, to non-conducting, when it is below 2.5V, so you just select the divider resistors to generate that sense voltage at the desired battery detect voltage.
The TL431 requires a minimum cathode-anode current of 1mA when conducting so those resistors are selected accordingly.
