Turn on LED's after a specific voltage level
Riddersholm
Joined Jun 1, 2019
9
Hi.
I have a circuit with 3 voltage levels: +40V, +8V and +5V. I want to detect if these voltage levels are present using 3 LED's.
My idea is that when the voltage levels are below 10% of the required levels, so +36V, +7.2V and +4.5V respectively, I want the LED's to turn on. When the voltage levels are above, they turn off.
Any idea how to do this, maybe using comparators?
jpanhalt
Joined Jan 18, 2008
11,087
Welcome to AAC.
A voltage comparator is often used for such purposes. You can use one reference voltage (such as a zener) and voltage dividers to get to the appropriate voltage of each source for the reference voltage. If you need to invert the output, a simple inverter will do it, but that can often be avoided.
From a digital prospective, you can use a voltage dividers and an ADC (analog digital converter). I assumed you wanted an analog solution.
ericgibbs
Joined Jan 29, 2010
21,567
hi,
A Quad LM339 comparator IC, could be used, resistive voltage dividers and say 3 potentiometers to Set the threshold voltages.
Do you have a sketch to post.?
E
Dodgydave
Joined Jun 22, 2012
11,395
Here is a circuit using the TL431, set the required voltage with the preset, use a 4.7K series resistor for the 40V supply. As the voltage drops below the set voltage, the led turns on.
AnalogKid
Joined Aug 1, 2013
12,265
A quick innergoogle search found this. It is close to what you describe. In your case only 3 sections are used, and each has its own input.
Important: how is the monitor circuit to be powered? You could diode-OR the 5 V and 8 V inputs together on the assumption that both will not be out (or below 4 V) at the same time, or have some other, independent power source. How it is powered affects everything else, so it needs to be decided first.
http://www.circuitdiagram.org/battery-monitor-using-lm339-ic.html
ak
Riddersholm
Joined Jun 1, 2019
9
Hi again Dodgydave.
Thank you again for your answer, the TL431 perfectly suits the job.
In the datasheet for the TL431, I came across the curcuit shown below, which is the same curcuit you draw, but with a upper voltage limit.
How do i calculate the values for R3 and R4, so that the current through the LED is 20mA? Let's say the LED has a forward voltage of 2.2V.
jpanhalt
Joined Jan 18, 2008
11,087
Did you notice this:
At 20 mA, that will rapidly drain most batteries.* Modern LED's are easily visible at 1 mA to 2 mA. You might also want to configure it so no LED is on when "Low Limit < V(batt) < High Limit". Of course, that also can create problem by over discharging the battery.
*A 1000 mAh battery is fully drained by that LED in 50 hours with no other load. Moreover, such deep discharges may not be healthy for the battery.
Dodgydave
Joined Jun 22, 2012
11,395
Hi again Dodgydave.
Use the circuit on post #9 that I gave you, it only uses one TL431 per led.
Riddersholm
Joined Jun 1, 2019
9
The curcuit i want to detect the +40V, +8V and +5V voltages isn't powered by a battery, but i still want to detect the voltages.
If the current through the LED is set to 2mA, how do i then calculate the values for R3 and R4? And yes, the LED's is only ON if the voltage is too low/high.
jpanhalt
Joined Jan 18, 2008
11,087
That is not what the design you show does. According the the datasheet from which that circuit comes, the LED will be on only when the voltage is within the low and high limits. In other words, the opposite of what you just said.
